Hello everyone,
I was wondering does anyone know whether there is a difference between a starter motor from a manual or auto supra. My starter motoer is stuffed and the only one the spare parts guy have is from an automatic supra. Any body know or can give me any advice would be appreciated. |
#2 | |
![]() Quote:
http://carfiche.com/fiche009/jza80/ However, a quick call to Jeff Watson 800-327-2087 (Champion Toyota) will get you the answer.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
Thanks pwanas but Im all the way from australia.
Cheers. |
Got it. Hopefully you have a local 'yota dealer/distributor that can help you...
Thanks Travis89turbo. Now I wont have to take mine off to check!!!
#6 | |
![]() Quote:
1995 Toyota Supra SE 71k miles. Master power T70 stock 2jzge 1989 Toyota Supra. 1jzgte swap 5 speed of course.. Driftmotion 60-1 single turbo kit. Cxracing FMIC. 2jz 550cc injectors... soon to come..... EMS Stinger. BC 264 cams 680cc injectors Spec stage 4 clutch and A LOT of boost!------SOLD 1999 Ford F350 diesel 2004 Jaguar XJR Supercharged If it hasnt broke you haven pushed it hard enough!! |
Starter Removal question | OkieRA29 | MKIII Supra | 13 | 05-11-2010 12:08 AM |
90 mkIII starter connections | doodah | MKIII Supra | 1 | 11-11-2008 06:14 PM |
How to quickly test starter | CyFi6 | MKIII Supra | 4 | 11-30-2007 01:57 AM |
starter removel? | swied | MKIII Supra | 4 | 04-23-2007 04:50 AM |
