Old 09-17-2010, 12:45 AM   #1
localrager
localrager is on a distinguished road
Default New Car New Issues
Hello all, my name is Keith and I Just picked up a 94 TT yesterday. Car is mostly stock. 140k. Rebuilt at 93k.
Today (day after i get it) I get the Master Warning light. I check it.. "Check Engine" light flashes 1x then 4x so im guessing code 14 {Ignition signal}. What does this mean?
Also the "O/D off" light flashes 8x then flashes 9x. I dont know what that means if anything.
The car ran fine during test drive and the 1 1/2 hr drive home. No issues whatsoever.
Im new to the Supra so any help will be appreciated.
localrager is offline   Reply With Quote
Old 09-17-2010, 02:23 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
According to this...
http://www.mkiv.com/techarticles/eng...bd1_codes.html
... you have one ore more of the following:
  • Open or short in IGF circuit from igniter to ECM
  • Igniter (problem)
  • ECM (problem)
Most likely it's the first or second possibility. If you know of someone else with an Mkiv TT, try swapping out with his/her ignitor.
Life begins at 30psi.
Old 09-17-2010, 03:31 PM   #3
localrager
  • Igniter (problem)
  • ECM (problem)
Ok, so basically i should invest in the supra repair manual and trouble shoot this thing. Hopefully its just a bad Igniter.
Do you know what the flashing O/D light means? Perhaps its just telling me that the car is in "Test Mode"?
Old 09-17-2010, 11:15 PM   #4
localrager
Ok so i start the car today after jostling a few wires around now its giving me codes 25, 26 and still 14.
25 is lean
26 is rich
What the hell is going on with this car??
Could the new codes be due to the possible faulty igniter?
The plot thickens.. I pulled the plugs, they are all pretty bad. The strange thing was the first 4 plugs were Bosch Platinum FR7DP. The last 2 were Denso PK20R11.. Why? Why would the last 2 be different? Are they a hotter burning plug?
Old 09-19-2010, 02:21 AM   #5
pwpanas
Supra Owner
pwpanas's Avatar
25 is lean
26 is rich
If the a/f is very lean, the spark may not ignite consistently. However, when the spark doesn't ignite, the exhaust is very rich (because no fuel was burned). Makes sense?
The plugs should not be different. Go with oem platinum plugs, or NGK 6097s.
Old 09-19-2010, 11:59 PM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Actually a new ignitor is over $400USD. Your least pricey option to correct is faulty wiring.
Cold start issues??? Stanghunter MKIII Supra 1 07-19-2010 08:48 PM
Personal issues Crazee MKIII Supra 2 07-30-2009 06:25 PM
Transmission Issues xpurplepandasx MKII Supra 6 08-23-2007 02:12 AM
fuel injector issues doc1 Non-Generation Specific Questions 5 03-30-2007 04:08 PM
Wiring issues sstvns Non-Generation Specific Questions 1 10-05-2005 07:49 AM
