#1 |
Okay I decided to go about this a different way... I live in Canada and imported a JDM mk4 Supra, twin turbo. I want to know where to start for upgrades, I got deep pockets as I've been working in the oilfield for the past 6 months. I know all about BPU and APU.
I'm thinking; Full 4" exhaust for max power Intake Greddy BCC (Boost Cut Controller) Boost Controller Blow Off Valve Hosing (Can't stand when stock hosing cracks and you get leaks and shit) Turbo Timer Intercooler Cam Gears? (5 bolt) Cam Shaft? What about things like injectors? I am tempted to just wait and put in a whole twin fuel system for 2000 instead of just injectors? I'm also aware about things called Plug n Play? They are ECU upgrades or fuel system upgrades that are already set to go? Is this a good idea or is it better to do a full installation instead of this instant stuff? As well as intake manifolds? What about other things like fuel regulators or different o2 sensors, I heard the stock ones aren't very accurate. I haven't looked around to compare brand yet but if I am spending this amount of money on the car I am going to put the best of the best stuff in it, maybe not a 2000$ air filter, but I'm not going to put in wal-mart brand stuff. If anyone can answer any of these questions let me know, as well as brand suggestions. Thanks, Kyle PS: I'll posting pictures of my baby as soon as it gets here ![]() |
#2 | |
Supra Owner
![]() Quote:
If you want the exhaust for show (even if it's not necessary for your power goal), I absolutely understand. No harm in looking & sounding bad@ss. ![]() The oem fuel pressure regulator is very accurate. However it is not adjustable, and it doesn't flow enough for an aftermarket fuel system with multiple/larger fuel pumps. The oem O2 sensors are plenty accurate too, and work fine with the oem ecu. However, they aren't sufficient for "wideband" a:f tuning. Plug and play is just a term for any product that has OEM Toyota electrical connectors on it. This saves you and/or your installer time doing wiring when installing aftermarket electronic components. Btw, the only hose I know of that cracks is the hose between the EGR valve and the EGR vacuum modulator. You'll also need to replace the hoses around the BOV when you replace it. If you want to do all of the other hoses too, to have a great looking engine bay, I understand. Silicone hoses withstand heat the best. Lastly, don't forget about a boost gauge, and a budget for race fuel. Oh, and an aftermarket downpipe will make you waaaay more power than an aftermarket exhaust at the BPU level.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 10-23-2010 at 01:21 PM. |
#3 |
Thanks for the help, I'm hoping for anywhere between 450-500whp this spring but eventually I want to make about 800whp.
As for exhaust, I meant like full turbo-back. So a new downpipe included. |
#4 | |
Supra Owner
![]() Quote:
For example, 450rwhp is achievable via BPU++++, with a low mileage/hours engine (i..e GREAT compression and leakdown numbers) and a low mileage/hours set of turbos. However 500whp is NOT feasibly achievable via BPU++++, regardless of engine/turbos condition. If you want 800 later, you will 100% for sure need to uninstall and resell some aftermarket BPU parts that you are buying now, at that time. If you're okay with doing this, let's just completely forget about 800 for now. However, if you're not okay with the inconvenience and cost of buying, installing, uninstalling and reselling BPU-specific parts, let's just get you to 800 right now. Just mho, fwiw. Lastly, note that there's no need to "hope". We can absolutely 100% for sure achieve any one of these numbers. Any one of them is simply a matter of carefully invested $, time, and expertise. True, but you'll get all you need for BPU with a $300 downpipe. Just so no one else reading this thread is misled, you really don't need to buy the two together.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 10-23-2010 at 10:41 PM. |
#5 |
okay well lets just set it up so 800-900whp is possible, the parts may be more expensive now but I'm not into the inconvenience.
#6 | |
Supra Owner
![]() Quote:
After we get that nailed down, I'll need to know your application. Oh, and is your Japanese-spec Mkiv Supra Turbo an auto or a 6spd? By the way, have you read these two threads from the MKIV FAQ?Lastly, it's not only that the parts are more expensive for 800+rwhp...you have to upgrade many more of them. Examples: For BPU, you don't need a new exhaust manifold, but for aftermarket turbos, you do need to replace the oem exhaust manifold with an aftermarket exhaust manifold/header. For BPU, you use the oem ecu. For 800+rwhp, you'll need to replace the oem ecu with an aftermarket ecu. Etc., etc., etc...
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 10-24-2010 at 01:13 AM. |
Performance Cap and Rotor? | btwilson86 | MKIII Supra | 9 | 08-02-2010 03:11 PM |
Changes to a N/A Supra to increase performance | Sup93a | MKIV Supra | 9 | 02-02-2010 03:14 AM |
Max safe long straight performance in a road race? | Humba | MKIV Supra | 7 | 12-25-2008 05:38 AM |
Edo Performance Party and Car show (SoCal) | promark | MKIV Supra | 0 | 05-27-2008 09:56 PM |
Gtech Performance meter | landspeedxxx | MKIII Supra | 4 | 04-24-2006 05:45 PM |
