Old 11-01-2010, 08:23 AM   #1
admux
admux is on a distinguished road
Default Automatic Transmission not engaging
Hi all,
I've bought a 94 mark IV Supra NA.... Its been given a good hammering by previous owners and still works but with a few problems..
The worst issue is that the transmission slips / not engages when under load (going up slopes) at low speeds
An example would be driving up a slope in a multi-story carpark, I have to go slow to avoid scraping the bottom of the body kit and exhaust on the speedbumps i'm in D (drive) and when I come off the gas and go back on the gas it disengages the gear and start rolling backwards, I have to brake and then gas up up again ....or let it roll back and wait for it to re-engage (no good when cars are behind you)....
I don't seem to have an issue on the flat....
Another (an probably related issue) is there seems to be no kickdown when you floor the gas pedal, it stay in the gear you are in and speeds up without dropping to a lower gear.
All this points to a tranny problem... I checked the tranny fluid and it looked ok (red and not burnt) but it was way overfilled, I pumped some out and it's at the correct level now...
any thoughts ? is a tranny re-build imminent ?
ta,
Addy
admux is offline   Reply With Quote
Old 11-02-2010, 06:35 AM   #2
Originally Posted by admux View Post
Hi all,
ta,
Addy
I assume it's an automatic transmission? If so, I agree with you that a transmission rebuild is likely (probably bad sprag(s)). However, these transmissions are pretty rugged and typically don't go out unless the horsepower has been increased (eg. via nitrous oxide injection for an n/a). It may be cheaper for you to find another transmission in a junkyard, and it should work just fine.
I also agree with you that the kickdown problem is probably related too. However, that kickdown switch is a separate circuit and in theory it could have an electrical problem. The switch is under the carpeting, right under the accelerator pedal.
Old 11-04-2010, 06:53 AM   #3
admux
quick update on this.... I topped up the tranny fluid, put about another 500ml in it and it's stopped slipping.
defo something wrong with the tranny but it behaves better when u overfill the fluid
next job is the manifold.... it has a hole so it's bit noisy !!! head turner though
Old 11-07-2010, 04:56 PM   #4
Be careful. An overfull auto tranny can be a fire hazard. If it's driven hard, tranny fluid can splash from the overflow valve onto the exhaust.
Old 12-02-2010, 06:57 PM   #5
lawlerCoaster
lawlerCoaster is on a distinguished road
quick update on this.... I topped up the tranny fluid, put about another 500ml in it and it's stopped slipping. hid kits
Post some pictures of your car! =)
lawlerCoaster is offline   Reply With Quote
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Automatic transmission strength pgoughary MKIII Supra 0 12-29-2006 06:48 PM
automatic transmission dblonka MKIII Supra 0 09-22-2006 03:02 AM
JDM Automatic Transmission Problem-Please help! hbear1300 MKIII Supra 2 07-22-2006 10:08 PM
