Hi all,
I've bought a 94 mark IV Supra NA.... Its been given a good hammering by previous owners and still works but with a few problems.. The worst issue is that the transmission slips / not engages when under load (going up slopes) at low speeds An example would be driving up a slope in a multi-story carpark, I have to go slow to avoid scraping the bottom of the body kit and exhaust on the speedbumps i'm in D (drive) and when I come off the gas and go back on the gas it disengages the gear and start rolling backwards, I have to brake and then gas up up again ....or let it roll back and wait for it to re-engage (no good when cars are behind you).... I don't seem to have an issue on the flat.... Another (an probably related issue) is there seems to be no kickdown when you floor the gas pedal, it stay in the gear you are in and speeds up without dropping to a lower gear. All this points to a tranny problem... I checked the tranny fluid and it looked ok (red and not burnt) but it was way overfilled, I pumped some out and it's at the correct level now... any thoughts ? is a tranny re-build imminent ? ta, Addy |
#2 | |
![]() Quote:
I also agree with you that the kickdown problem is probably related too. However, that kickdown switch is a separate circuit and in theory it could have an electrical problem. The switch is under the carpeting, right under the accelerator pedal.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 11-02-2010 at 06:43 AM. |
quick update on this.... I topped up the tranny fluid, put about another 500ml in it and it's stopped slipping.
defo something wrong with the tranny but it behaves better when u overfill the fluid next job is the manifold.... it has a hole so it's bit noisy !!! head turner though |
#4 | |
![]() Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#5 | |
![]() Quote:
![]() ![]() Post some pictures of your car! =) |
1986 Turbo Automatic Transmission Rebuild? | professorbob | MKIII Supra | 2 | 01-26-2012 01:06 AM |
Should I try to rebuild my transmission, or leave it to experts? | Busted Knuckles | Non-Generation Specific Questions | 1 | 04-15-2008 01:20 AM |
Automatic transmission strength | pgoughary | MKIII Supra | 0 | 12-29-2006 06:48 PM |
automatic transmission | dblonka | MKIII Supra | 0 | 09-22-2006 03:02 AM |
JDM Automatic Transmission Problem-Please help! | hbear1300 | MKIII Supra | 2 | 07-22-2006 10:08 PM |
