Old 11-22-2010, 04:34 PM   #1
ausupra
ausupra is on a distinguished road
Default 2JZGTE Crank torque specs
Hey,
I'm about to pull the old girl to bits to do some fabrication, then I'll put her back together. I've been advised that the optimal torque for the crank is 15 ft/lb over standard but can't find standard torque specs for the life of me.
What is your crank torqued at? I have the ARP head/main studs.
Thanks
ausupra is offline   Reply With Quote
Old 11-22-2010, 06:46 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by ausupra View Post
Hey,
Thanks
Do you have a TSRM? All the torque specs are in there. You shouldn't be pulling "the old girl to bits" and putting "her back together" without the TSRM.
Life begins at 30psi.
Old 11-23-2010, 03:19 AM   #3
ausupra
Thanks for the reply.
I do have one, but couldn't find the torque specs - maybe something I missed...
I'll have another look.
But I also just wanted to get some feedback to see what others were doing, especially those who are pulling 1KHP+, as that's what I'm aiming for.
Have to do alot of the research myself here as it's not like in Oz/US where the workshop guys really know what they're doing - here it's a bit 'same pattern, all cars', they won't check to see your car needs something more.
Old 11-23-2010, 01:59 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
I can check my TSRM to verify if you can't find it. Note that the oem shortblock - bone stock - is good for 1k hp...so the TSRM torque specs are plenty fine for that hp level.
By the way, which "crank torque spec"? The mains? The connecting rod bolts (crankshaft end)? The front harmonic dampener bolt? The rear flywheel/flex plate bolts? I'd guess you mean the mains, but please confirm.
Also, have you considered aftermarket mains?
Old 11-23-2010, 02:35 PM   #5
ausupra
Thanks again.
Yeah, I wanted the specs for the mains. I have got the Titan Billet Main caps, ARP head and main studs, Titan Billet Pistons, BC rods - I decided this was the year to finally get things going, but now that I've set the goal at a different level, it seems lots of the mechs I've gone to don't know how to take it to that level.
I have a mech working with me, he knows the assembly, but we were torquing it at 90lb/ft, which some people replied with a about, while some thought it was fine, and should even be torqued more. So, I thought I'd go back to basics and try to get the stock amount, and I had it recommended it to me that I go 15lb/ft over but I just couldn't find stock anywhere to have a number to go off and felt like I'd read the spots of the TSRM.
Thanks for any advice you could give. I've gone through 3 blocks now and am giving up!
Old 12-05-2010, 03:44 PM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Thanks again.
Were you able to find the torque specs in the TSRM? If not, I'll dig mine up and look it up for you...
Torque specs for 7MGE alwayspissedoff MKIII Supra 5 07-02-2010 11:56 PM
Help on head bolt torque specs omar MKIII Supra 3 07-29-2009 11:35 AM
torque specs for rod berings and pressure plate jcastro MKIII Supra 5 05-21-2009 11:29 PM
Torque Specs 87MK111Supra MKIII Supra 7 03-09-2009 10:28 PM
Need torque specs... VigilanteVixen007 Non-Generation Specific Questions 5 09-19-2005 11:47 AM
