Old 02-06-2011, 06:52 AM   #1
walter100
walter100 is on a distinguished road
Default gear box noise 98 supra
hey my supra makes a rattling,clunking noise when you put it in first and let the clutch and when you change from first to second, the noise can be heard from out side the car clearly,has any one heard of this problem.
walter100 is offline   Reply With Quote
Old 02-06-2011, 01:58 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
I've driven and been around literally hundreds of Mkiv Supras ... many of them 6spds.. and I honestly can't recall hearing a noise like you've described. Did you have any work done on it recently? If I were to guess, I'd say the noise is either an improperly installed clutch or a loose exhaust component (the oem exhaust is connected to the transmission with a brace). Can you upload a .wav or video so I can hear the noise?
Life begins at 30psi.
My toyota supra 1998 twin Turbo vvti suddenly developed a loud exhaust noise, anyone irishsupra MKIV Supra 0 08-18-2010 09:54 AM
Supra makes wierd rattling noise after 3000 rpm on every gear HELP! 89MkiiiSupra MKIII Supra 5 08-20-2008 03:53 AM
Potentially buying 1987 Supra Turbo with knocking noise saturnvii7 MKIII Supra 3 04-24-2007 05:59 PM
