hey guys
At the moment Im trying to change the water pump and timing belt on my 93 na 3L 6cyl supra. The problem is to get to water pump I have to get main crankshaft pulley off. Does anyone know whether the bolt on the pulley is a right or left hand thread? Is there any other way of doing it without taking off crankshaft pulley? Any comments would be appreciated Cheers ![]() |
#2 | |
![]() Quote:
Just curious...why do you ask? Are you having trouble getting it off?
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 02-12-2011 at 02:54 PM. |
Thanks for the response pwanas, just wondering is there a special tool that can be used to get the pulley off. Tried to put a bar to try and crack nut off but is very very tight!!!
Any other advice would be appreciated. Cheers ![]() |
#4 | |
![]() Quote:
One step at a time - right now, your problem is that you can't apply enough power to the bolt with the tools you have. The solution to that specific problem is that you simply need more leverage. You need to find/buy/beg/borrow/steal a long, strong pipe that fits the end of your pry bar. Put the pipe on, and push. With a long enough pipe, you could flip your car over, or tear the engine off the motor mounts. However, something else will happen first. For example, your clutch may slip (if you have a 5spd). Post back and tell us what happens next.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
Hey,
I made a special tool, I got a steel bar and welded the socket to the end of it. I then put a pipe at the end of that as well to get leverage. When we tried to pull on it, it started to bend the steel bar!! I have no idea why its so friggin tight. Is there anything else I can do!!!!????? ![]() |
#6 | |
![]() Quote:
Hopefully you're using a six-sided impact-grade socket. You are turning it counterclockwise, right? Sorry...I had to ask.
Timing belt install | superwhite | MKIII Supra | 4 | 02-02-2011 07:09 AM |
91 NA water pump | csk239 | MKIII Supra | 8 | 05-09-2008 08:21 AM |
timing belt | D_Train | MKIII Supra | 4 | 01-09-2008 05:34 PM |
Bad Water Pump? | scruffboy | Non-Generation Specific Questions | 10 | 11-26-2006 04:37 PM |
1gte water pump | streetbeast | MKIII Supra | 15 | 06-24-2005 08:02 PM |
