Old 02-15-2011, 12:28 PM   #1
toysuprapr
toysuprapr is on a distinguished road
Default Blue Smoke....
Every morning i start up my car and blue smoke shoots out of the exaust then stops. Some people told me thats it could be the turbo seals others told me it could be the valve seals. Any engine tests i could get done on my engine to confirm the problem?
toysuprapr is offline   Reply With Quote
Old 02-15-2011, 02:00 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
Unfortunately there is no test other then to take your exhaust off and see if there is oil in the turbo... the exhaust side is where both of my ct26 seals blew out. but it could possibly be the compressor side... you are talkin about a 7m right?
Could also be valve seals. I just got done replacing mine on my jz. They were rock hard and one had fallen apart. You can see if the exhaust side is leaking by pulling off the manifold and lookin at the valves. If they are bad they will have oil seeping. Valve seals can be replaced with the head on!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 02-15-2011, 02:19 PM   #3
toysuprapr
sorry man, i should have posted i have a 94 TT a/t
Old 02-15-2011, 02:58 PM   #4
Travis89Turbo
Sorry I should of read what section this was in. The ct12b on the 2j are good quality turbos. The valve seals that were used for some reason have a high failure rate... I used felpro seals as a replacement cuz they are made of a Viton rubber which is very durable..
Here is a good how to....
http://www.mkivsupra.net/vbb/showthr...al-Replacement
Ps. Get the valve spring tool it is worth the money.. I used long long nose needle noses to pull old seals out and it worked good! But get the valve keeper tool!
stock 2jzge
Old 02-16-2011, 09:40 PM   #5
pwpanas
Supra Owner
pwpanas's Avatar
Here's what I consider to be an even better Valve Stem Seal article:
http://bellsouthpwp2.net/p/w/pwpanas...ra%20Turbo.htm
...however I am a bit biased. Read the article and you'll see why.
Life begins at 30psi.
Old 02-16-2011, 10:14 PM   #6
Travis89Turbo
LMAO..... This is definatly a better site. This is the one i used on my 1j. For some reason I couldn't find it again whn I seen this thread!
stock 2jzge
Help me!!! imseeinred Exterior , Interior, and Detailing 2 10-20-2010 07:01 AM
white and blue smoke after rebuilding head block ahruizguerra MKIII Supra 2 10-01-2010 07:50 PM
Blue Smoke turbomk529 MKIII Supra 2 08-14-2008 02:25 AM
NEED HELP!!-my 89 mik3 emitts blue smoke quickfingas MKIII Supra 1 05-04-2006 12:54 AM
Oil n smoke from turbo wolfen Non-Generation Specific Questions 0 10-30-2005 12:27 AM
