RHD NAand 5-speed
Theres a 5-speed and NA. How much would it run me to swap it to 6speed and to single turbo
Do u wana stick with the ge or go with a 2jzgte and doing the swap from 5speed to 6 is going to be alot of fab work you have to cut the tunale and weld in a new one and also will need the to go the the 2jzgte rear end And a 6speed trans alone is going to be around 5 grand and as far as turbo kits it depends how much power you are looking for
Trannys can be found for around 3k. Click here to learn how http://www.mkiv.com/techarticles/auto_to_6spd_swap/ Turbo kit here... I run this 60-1 turbo from driftmotion. And trust me its bad to the bone. http://store.driftmotion.com/static/...-1turbokit.php Oh. You should really add more details to your first post. Don't be shy on words. Or atleast give us a yr! This kit from driftmotion needs a lil modification for rhd. Any welder could do it. |
