Theres a 5-speed and NA. How much would it run me to swap it to 6speed and to single turbo
Do u wana stick with the ge or go with a 2jzgte and doing the swap from 5speed to 6 is going to be alot of fab work you have to cut the tunale and weld in a new one and also will need the to go the the 2jzgte rear end And a 6speed trans alone is going to be around 5 grand and as far as turbo kits it depends how much power you are looking for
#3 | |
![]() Quote:
Trannys can be found for around 3k. Click here to learn how http://www.mkiv.com/techarticles/auto_to_6spd_swap/ Turbo kit here... I run this 60-1 turbo from driftmotion. And trust me its bad to the bone. http://store.driftmotion.com/static/...-1turbokit.php Oh. You should really add more details to your first post. Don't be shy on words. Or atleast give us a yr! This kit from driftmotion needs a lil modification for rhd. Any welder could do it.
1995 Toyota Supra SE 71k miles. Master power T70 stock 2jzge 1989 Toyota Supra. 1jzgte swap 5 speed of course.. Driftmotion 60-1 single turbo kit. Cxracing FMIC. 2jz 550cc injectors... soon to come..... EMS Stinger. BC 264 cams 680cc injectors Spec stage 4 clutch and A LOT of boost!------SOLD 1999 Ford F350 diesel 2004 Jaguar XJR Supercharged If it hasnt broke you haven pushed it hard enough!! Last edited by Travis89Turbo; 03-07-2011 at 10:23 PM. |
5 speed to a 6 speed | supraman623 | MKIV Supra | 14 | 06-30-2013 11:59 PM |
help swapping a 5 speed for an auto | bbullsj | MKIII Supra | 12 | 02-17-2011 02:15 AM |
Blitz MSTT Speed adjustment | SunDan | MKIII Supra | 5 | 11-17-2009 07:41 AM |
speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
