Old 05-08-2012, 01:54 AM   #91
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
Hi me again.The head should be finish next week can wait.So i hade some money to spent so bought a new turbo a garret rated at 700hp.Can any one help me i want to buy full slicks MT or MH was thinking of getting 26/15/11 will it fit.
Sorry not sure. I know 315mm width rubber fits with the correct offset of rim.
I'm also 100% sure you won't fit 15s with TT brakes - you'll have to downgrade the rear brakes to Mkiv n/a rear calipers and rotors.
Life begins at 30psi.
Old 05-09-2012, 03:38 PM   #92
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Default Need help making power 94TT
The 15 inch rims fit.fitted them last night must get the right offset.
warmkop is offline   Reply With Quote
Old 05-11-2012, 12:22 PM   #93
pwpanas
Supra Owner
pwpanas's Avatar
You must not have rear TT brake calipers then...
Old 06-07-2012, 05:25 PM   #94
warmkop
Moderator
warmkop's Avatar
Default Need help making power 94tt
Took my crank pulley of but broke it it was stuck can i replace it with a aluminium pulley.
Old 06-07-2012, 08:58 PM   #95
pwpanas
Supra Owner
pwpanas's Avatar
I'd recommend against this course of action. What you took off wasn't (just) a crank pulley - it's a harmonic dampener too. You need to replace it with another harmonic dampener + pulley ... either a new oem one, or ATI or any of the other aftermarket dampeners for the 2jz-gte. Please post if you have questions about any particular brand (other than oem or ATI, which both work fine).
Old 08-08-2012, 04:58 PM   #96
warmkop
Moderator
warmkop's Avatar
Default NEED HELP MAKING POWER94tt
So i bought a 2nd hand pulley on ebay still in good cond.starting to assemble now can wait to get her finish.Also bought new dumpvalve gates timing belt and a few other stuff,spend some time polishing as i assemble here is some pics of the parts i polished and a pic of the head after the engineering.
Old 08-10-2012, 12:17 AM   #97
pwpanas
Supra Owner
pwpanas's Avatar
Great looking work! Thank you for posting the pictures - please keep them coming.
Old 08-21-2012, 06:11 PM   #98
warmkop
Moderator
warmkop's Avatar
Hi. i have a bit of a problem i cant find my vsv valves on the turbo side what will the managment do with out them.
Old 08-21-2012, 06:39 PM   #99
pwpanas
Supra Owner
pwpanas's Avatar
All plug-and-play standalone engine management systems can be configured to ignore these VSVs if you go to a single turbo setup. For the oem twins, the appropriate map for that plug-and-play standalone ecu system will already be configured to recognize those VSVs on the appropriate oem harness connector pins.
Old 08-21-2012, 06:58 PM   #100
warmkop
Moderator
warmkop's Avatar
one of my waterlines on the iac broke wil the car give lot of problems with out the water lines
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
