Old 10-30-2012, 11:06 PM   #121
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
found the fault injector 2 wire pulled out of the plug.
Congratulations on troubleshooting that unusual problem.
Thanks for posting and keeping us updated.
Take care,
Phil
Life begins at 30psi.
Old 11-05-2012, 05:35 PM   #122
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Default Need help making power 94tt
So tuner thought it was the cooler that blew apart but was just the boost pipe on the cooler that came off.
we battle tonight with the wastgate it just wont open will have to take it off and look at it.
car is dyno halfway just the wastgate that is giving us problems boosting way to much.
warmkop is offline   Reply With Quote
Old 11-07-2012, 11:00 AM   #123
pwpanas
Supra Owner
pwpanas's Avatar
Try running the boost straight into the side of the wastegate, just as a test.
Old 11-12-2012, 04:39 PM   #124
warmkop
Moderator
warmkop's Avatar
wastgate was bypassing vacuum,fixed now hopefully we can dyno her this week with no problems. some random pick i took friday.
Old 11-15-2012, 03:40 PM   #125
warmkop
Moderator
warmkop's Avatar
1.4 bar boost.
Old 11-16-2012, 12:43 AM   #126
pwpanas
Supra Owner
pwpanas's Avatar
1.4 bar boost.
Wow - solid run! Time to crank it up with some race fuel (just for a test, of course)...
Old 11-16-2012, 05:22 PM   #127
warmkop
Moderator
warmkop's Avatar
That was with ethanol will boost her more first want to drive her on the track
Old 11-17-2012, 04:21 PM   #128
warmkop
Moderator
warmkop's Avatar
The car is overheating very fast wen i race her took out the thermostat but still overheating. so the fan clutch is not working will that cause it to overheat that fast or is it the waterpump.
What will cause the car to miss at so 6000rpm wen i rev her in neutral
Old 11-17-2012, 07:17 PM   #129
pwpanas
Supra Owner
pwpanas's Avatar
It's the fan. Also, be sure to run pure, distilled water (no antifreeze). Use Redline Water Wetter as an anti-corrosive.
Regarding the miss, check your spark plug gaps. How old are your plugs? Are they copper, platinum or iridium? What is the heat range?
Next possibility is the coilpacks - how many miles on them. If not that old (less than 75k miles), purchase one brand-new one, and swap it out for each one of the six till the problem is fixed.
Of course, if your coilpack connectors (plastic) are cracked/brittle, they need to be replaced.
Last (least likely) is the ignitor. Swap it with an ignitor from another Mkiv Supra Turbo to test.
Old 11-21-2012, 05:59 PM   #130
warmkop
Moderator
warmkop's Avatar
What will the reason be for my powersteering thats noisy after standing for a year
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
