Old 12-09-2013, 01:35 PM   #181
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
Yes I agree but if I do the aftermarket crank signal how do I do the timing how will the stock ecu read the signal and how do I cut the timing for the launch control
Your ecu is already using the oem crank signal just fine - why would you want to move it over to the aftermarket crank signal?
I'd need to know more about the details about your ecu and the details of your launch control "chip" to help further with how to cut the timing for the launch control. Could you post the complete configuration here? (eg. is the launch control simply a feature in the ecu you're using, or is it a separate 'box'? What is/are the brand(s) and model(s) of the ecu(s) that you're using? etc.)
Life begins at 30psi.
Old 06-08-2014, 02:19 PM   #182
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Sorry dam internet was off. im battling with my car again tried to set boost up but cant get it set nicely with the chip thinking off going aftermarket ecu
warmkop is offline   Reply With Quote
Old 06-09-2014, 08:49 PM   #183
pwpanas
Supra Owner
pwpanas's Avatar
Which one? AEM is plug-and-play...
Old 06-11-2014, 07:14 PM   #184
warmkop
Moderator
warmkop's Avatar
We dont have aem
Want to use Power mods
Old 10-04-2014, 10:39 AM   #185
warmkop
Moderator
warmkop's Avatar
So im busy installing power mod ecu in my car did the turbos thrust again. wil let everyone know as soon as im finished with it and it was on the dyno.
also adding 2 ekstra breathers on the cam cover for the ekstra boost in case
Old 10-05-2014, 01:52 PM   #186
pwpanas
Supra Owner
pwpanas's Avatar
Generally, a sealed PCV system is recommended over breathers. Run all PCV ports to a catch-can, and then run the catch can to a vacuum source (either pre-turbo, or post turbo with a one-way check valve). There's also a way to run PCV to the exhaust:
http://static.summitracing.com/globa...1189_US_xl.jpg
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
