#11 |
Moderator
#12 | |
Supra Owner
Agreed those numbers are okay, but (fyi) a brand-new 2jz-gte reads about 170psi. I'd suggest you should also do a leakdown test.
Not at all, unless you have one of these: http://www.spracingonline.com/store/...ool_Valve/3643
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 04-10-2011 at 11:32 AM. |
#13 |
Moderator
Dit the test everything is fine.that part is expensive for something that i can make my self.
#14 |
Supra Owner
Good luck. The tolerances required to make that valve effective are VERY tight.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#15 |
Moderator
i bould parts for powerstations so tolerances is not a problem.How effective is cutting the standerd cams or is it better to buy cams.
#16 | |
Supra Owner
![]() Quote:
http://www.hksusa.com/products/?id=656&rsku=4064 To get a longer duration, don't you need *more* 'meat' on the camshaft? I believe you'd have to do more than just cutting...
#17 |
Moderator
Thanks for the advice so far its been very helpful.
What cam wil you say is the best to use and wat can i rev the motor safely. |
#18 | |
Supra Owner
![]() Quote:
For your application, these HKS 272 duration cams will do nicely: 2202-RT085 and 2202-RT086 (note these only work on the '93-'98 non-VVTi models) With the oem valve springs, max 8500rpm is safe. With dual springs and titanium retainers, 9500+rpm is easily doable. Add shimless buckets to the setup and it should be good for 11K (no kidding - again, that's with a bone-stock oem shortblock!). However, note that you don't really make your power with rpms alone in the 2jz-gte. The turbo is so integral to the overall performance...the turbo-driven horsepower curve will usually taper off after about 8000-9000rpms. You'll want to set things up so that your shifts maximally captialize on that horsepower curve. Use the nos as an aide to spool up the turbo quicker and you'll widen that horsepower curve even more.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 04-23-2011 at 07:45 PM. |
#19 |
Moderator
how good is the standard intercooler and at power should it be changed.
should i install a bigger oil cooler |
#20 | |
Supra Owner
![]() Quote:
You should only install a bigger oil cooler if you're going to be roadracing at 700rwhp+, imho.
Greetings! | importauto | Import Auto Center | 7 | 06-21-2009 07:42 AM |
Help needed in first pass at improved appearance | finaltable | Exterior , Interior, and Detailing | 1 | 06-29-2008 06:34 AM |
Before buying an 85 P Supra with 123k what to look for | e30cabrio | MKII Supra | 0 | 02-24-2008 08:09 PM |
6 point Roll Cage? | carl johansson | Road Racing & Autocross | 0 | 12-01-2007 12:28 AM |
MEET UP's | TEAM_Bastos | Drifting | 0 | 03-02-2006 09:09 PM |
