Old 12-14-2011, 07:42 PM   #71
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Default need help
Wil do that, wil clean out wat i can and flush the enjin. I finished my flywheel but it is weighs 4 kilos more so wil just machine a bit more off. wil send some pics of the flywheel.thanks
warmkop is offline   Reply With Quote
Old 12-14-2011, 11:46 PM   #72
pwpanas
Supra Owner
pwpanas's Avatar
Very cool. Again, please note that extra flywheel weight is actually a benefit for drag racing a turbo car w/manual transmission during the launch. Bogging off the line is the biggest potential problem, followed closely by excessive wheel spin. Wheel spin can be managed by artfully feathering the clutch.
Of course, be sure that modified flywheel is perfectly balanced! I'd prefer if you could find a machine shop that has the capability of spinning the flywheel over 10k rpm for balancing purposes.
Life begins at 30psi.
Old 12-30-2011, 05:50 PM   #73
warmkop
Moderator
warmkop's Avatar
Default need help making power 94tt
Flywheel is finish will balance it next week then i can start putting everything together.
Old 12-30-2011, 07:02 PM   #74
pwpanas
Supra Owner
pwpanas's Avatar
Cool. Is it solid billet aluminum? ...or is it stainless? ...also, what does it weigh in total (with the ring gear)?
Old 12-30-2011, 07:20 PM   #75
warmkop
Moderator
warmkop's Avatar
Default need help making power94tt
It is EN 24 codisin T mild steel and it is 17.132kg
Old 12-31-2011, 01:37 AM   #76
pwpanas
Supra Owner
pwpanas's Avatar
That should work fine. Be sure to note that if you're going to be using a carbon-ceramic clutch disk material that you'll likely wear that flywheel out quickly if you're doing a lot of drag racing. The carbon-ceramic material is *much* harder than mild steel.
Old 12-31-2011, 08:30 AM   #77
warmkop
Moderator
warmkop's Avatar
The EN 24 mild steel is the hardest mild steel you can get but when it wears out i wil most likely go for a tilton clutch next.
Old 01-01-2012, 05:47 AM   #78
pwpanas
Supra Owner
pwpanas's Avatar
What if you machined a recess, and made a replaceable section (roughly a flattened doughnut shape) to deal with wear and heat spots? Best design would have the doughnut cut in three or four sections to deal with heat expansion, and of course recess the mounting screws.
Old 01-01-2012, 09:03 PM   #79
warmkop
Moderator
warmkop's Avatar
Default Need help making power 94tt
That will work that design is the same as what they use on the alluminium flywheels.
almost forgot happy b-day pwpanas.
Old 01-05-2012, 07:34 AM   #80
pwpanas
Supra Owner
pwpanas's Avatar
...Almost forgot happy b-day pwpanas.
Many thanks!
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
Help needed in first pass at improved appearance finaltable Exterior , Interior, and Detailing 1 06-29-2008 06:34 AM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
