Old 04-25-2011, 07:36 AM   #1
Alfa_Zulu
Alfa_Zulu is on a distinguished road
Default Engine locks at high rpm
When I run the engine close to the rev limiter the engine just locks briefly.
Thought it could be something to do with the valves not opening far enough to let the exhaust gasses out.
I'd appreciate any suggestions, and if you need more info just let me know
Alfa_Zulu is offline   Reply With Quote
Old 04-25-2011, 06:31 PM   #2
You're going to have to explain precisely what "locks" means to you. To me it's a seized engine and those aren't a temporary issue.
Old 04-26-2011, 11:37 AM   #3
Alfa_Zulu
Well it seems as though the exhaust gasses can't escape fast enough so some of it stays in the cylinder through the next intake and compression stroke causing to lock, a friend called it compression lock but I'm not real sure haha
Old 04-28-2011, 02:08 AM   #4
mike91
mike91 is on a distinguished road
your probably just hitting the fuel cut.
91 supra turbo targa
mike91 is offline   Reply With Quote
Old 04-28-2011, 05:49 AM   #5
Alfa_Zulu
No, this actually completely locks the drivetrain and the wheels for a brief second, if it was fuel flow it should just rev down shouldn't it?
Old 04-28-2011, 11:50 PM   #6
mike91
I'm pretty sure it could be. Kuz when I was doing some mods on my cars and hit fuel cut it felt like I hit a wall real quick and then kept going. And ya it happened when at high RPM. What mods have you done to your car?
Check engine light at high RPM's BlueTuner MKIII Supra 4 12-26-2009 08:37 PM
high speed(rpm) engine cuts out??? help!!! krahs912 MKIV Supra 3 08-14-2009 11:21 AM
turbo kit on high mileage engine supra_racer05 MKIV Supra 1 11-30-2007 11:37 AM
