Old 06-22-2011, 07:55 PM   #1
alldaysteve
alldaysteve is on a distinguished road
Exclamation Tuning Software Options
Hi all, I'm new to the forum and I'm looking to pick up a supra. What kind of tuning software is needed to tune the Mark 4? How expensive, and is there any wire cutting? What is Megasquirt and AEM?
alldaysteve is offline   Reply With Quote
Old 06-23-2011, 10:23 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
An oem mark 4 can't be tuned with software. However, you can put on aftermarket 'piggyback' ecus or standalone oem ecu replacements (eg. AEM), some of which need to be tuned with their brand-specific software. With the piggybacks and some of the stanalone ecus, there is wire cutting unless you use a field's harness.
By the way, why do you think you would want to "tune" an mk4...especially the TT? The air-fuel mixture and timing curve is already properly tuned to run under boost. If you want to increase the horsepower you need to find ways to raise the boost...not "tune" it. The aftermarket ecus are mostly for retuning after you've replaced the oem fuel injectors and increased the size of the turbocharger(s), if you want to modify your mk4 tt that extensively.
Life begins at 30psi.
Tags
tuning software
Is there anywhere that does ecu map tuning??? marcmann982 MKIII Supra 1 01-04-2011 05:17 PM
Software question J Robbins Non-Generation Specific Questions 1 01-11-2010 10:50 PM
AEM software question sleeperz MKIV Supra 2 07-18-2008 03:46 AM
my options. need suggestions OmeGa MKIII Supra 0 06-11-2007 04:33 AM
tuning question!! stainbox12 MKIII Supra 0 01-27-2007 04:36 AM
