Old 07-01-2011, 06:25 AM   #1
tayman1975
tayman1975 is on a distinguished road
Default Need help headlight problem
My high beams work and the low beam light beside the high beams. The outside low beams and smaller skinny lights on both sides stopped working alltogether. I noticed a clicking noise under the hood and it was the headlight relay. I replaced it and it still doesn't work. I checked all the fuses and there all good. I put a test light to the connectors where the light plugs in. There is no power there anymore. I can't figure it out. Any suggestions to check what it might be.
tayman1975 is offline   Reply With Quote
Old 07-24-2011, 06:48 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Follow the troubleshooting steps in the TSRM (Toyota Supra Repair Manual). It has to be one of harness, fuses, relays, etc. You'll probably need a multimeter to check continutity in the harness.
Life begins at 30psi.
headlight problem, need help 89supra884 MKIII Supra 0 10-19-2010 03:55 AM
MKIII Headlight Problem Supra275 Non-Generation Specific Questions 4 09-05-2008 09:06 PM
MKIII Headlight Problem Supra275 Non-Generation Specific Questions 0 08-26-2008 09:59 PM
headlight problem Supra Guestobrut89 Non-Generation Specific Questions 0 03-22-2005 12:54 AM
