Old 01-20-2012, 12:10 AM   #31
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by priyesh12 View Post
Just like you I washed my engine bay,
car ran fine when i started it, no issues but once i left the car running it begins to die. I checked my fuses and everything, and when it came down to the problem, it turned out that the alternator got wet and i ran it without it drying out properly. This burnt out the coils and hence the car would die randomly or loose power. I changed my alternator and everything works fine now. I hope this helps... sorry read that you solved the issue, I'm still sure it had to do with your alternator...
cheers
Congratulations on getting your issue solved. Did you also have to replace your coils?
Life begins at 30psi.
Old 01-21-2012, 08:04 AM   #32
priyesh12
priyesh12 is on a distinguished road
@pwpanas
Well I just replaced the entire unit, but once I opened the old alternator the coils were black so it was definitely the alternator coil that was causing the problem
priyesh12 is offline   Reply With Quote
Old 01-21-2012, 01:23 PM   #33
pwpanas
Supra Owner
pwpanas's Avatar
@pwpanas
Oh you meant alternator coils. Your previous post sounded like somehow the ignition coils had gotten burned out.
Old 01-21-2012, 08:40 PM   #34
priyesh12
Sorry for the confusion, yeah i meant the alternator coils. It was odd to have that give on me out of all the things that could go wrong from washing the engine bay. I was recommended to cover the alternator whenever you wash the engine bay :S, i guess it makes sense, although i have never heard of anyone doing that.
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
'86 2.8L starting problem daveydogtx MKII Supra 1 11-20-2010 04:34 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Nissan Sentra Tranny problem. redmaro Off Topic Forum 2 11-28-2006 01:58 PM
