Old 07-01-2011, 09:36 PM   #1
specie
specie is on a distinguished road
Default What's the avg cost of clutch installation?
I'm looking to have my clutch install soon and I was wondering what's the going rate for the labor. thanks.
specie is offline   Reply With Quote
Old 07-02-2011, 01:49 AM   #2
87hilux7mge
87hilux7mge's Avatar
i would call around to several shops and see what their clutch install includes, warranty information, and above all cost. prices differ across the states, and it will be a more worth while investment of time to check with some of your closest transmission/car repair shops.
to do the clutch on my freinds 98 jetta it cost him just over 500 bux.
Old 07-02-2011, 04:21 AM   #3
pwpanas
Supra Owner
pwpanas's Avatar
Don't let anyone touch it that has not changed the clutch on an Mkiv Toyota Supra turbo before. The procedure for this car is unique - it has several key differences from most other makes & models. It should cost about $400 in labor if you take it to a reputable, experienced shop. On a lift, with a transmission jack and two people who know exactly what they're doing, it can be done in four hours.
Alternatively, with the right tools you can do it yourself on high jackstands in about eight hours (you'll need a buddy's help during the job at two points, for about 15 minutes each time). You'll need to study the steps ahead of time, and be sure you have *everything* ready:
http://www.mkiv.com/techarticles/clutch/index.html
P.S. Don't give these instructions to 'bubba' at your local tranny shop - I can promise you he'll mess it up. A Getrag 6spd transmission is about $6K from Toyota......
Life begins at 30psi.
Old 07-02-2011, 04:50 PM   #4
specie
Thanks.
Where are you located at in GA?
Old 07-02-2011, 06:28 PM   #5
pwpanas
Supra Owner
pwpanas's Avatar
Thanks.
North-East of Atlanta
Old 07-03-2011, 09:09 AM   #6
97SupraTT
97SupraTT is on a distinguished road
X2 on not letting any shop do the change. With such a critical component, it can be messed up pretty easy. If you have the tools and know-how to do it yourself, I would suggest that.
97SupraTT is offline   Reply With Quote
Clutch kit for a 1993 JDM Toyota Supra SpRuCe Non-Generation Specific Questions 0 04-13-2009 10:20 PM
HElp with sports clutch!! whitequasimodo MKIII Supra 3 05-07-2008 11:06 PM
