#1 |
If I were to take a stock mkIV with a 2jzgte, and put somewhere in the range of $7,000(Mostly at a shop, some simple things I will do myself If there are such things) into the car what RWHP could I expect and what specs could I expect out of it? Going to be swapping in a low mileage jdm engine with a 6mt, but this $7k will be ontop of the new engine. I would like to have it still streetable and it will mainly be for roadrace/occasional 1/4 mile. Let me know what you guys think I could get out of it and thanks in advance.
Also, this is my first post so hey everybody! |
#2 | |
Supra Owner
![]() Quote:
Why swap in a jdm engine? Sure, the mileage might be lower, but the hours on the engine will probably be higher. Time spent idling (and revving) on the constantly-jammed streets of Tokyo is a big factor. Just offhand though, if you're going to both roadrace and drag race it, you're probably looking at a bpu+++ Mkiv at best for that max amount...which means about 425rwhp at best, reliably. Imho, there's no way you get a fuel system and an aftermarket turbo system on the car for that price, and then still have the $ you need for clutch, rims&tires, race fuel, and all of the other odds-and-ends you'll need for roadracing and drag racing.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#3 | |
![]() Quote:
And yeah, i realize that Labor will be alot of the cost. I don't want to do anything im unsure about and potentially ruin components of the car which is why I will probably do most of it in a shop. Thanks for answering by the way. I've read alot of other questions youve answered for other members, too. Most recently about the South Bend Kevlar clutch and Cyn-R-G flywheel I believe. |
#4 | |||
Supra Owner
![]() Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 07-22-2011 at 12:10 AM. |
#5 |
I have another question for you.
If I'm upgrading to a 3" downpipe and catback exhaust for bpu+++ but I plan to go to APU later on, would a 4" catback exhaust and downpipe be better at APU levels? if so, would I be able to skip the 3" downpipe and exhaust and go right to the 4" at bpu/bpu+++ so I don't have to buy two exhausts and two downpipes? |
#6 | |
Supra Owner
![]() Quote:
Tags |
$7k, 7000, faq, question, stock |
Thread Tools | |
Display Modes | |
Cold Start System Testing (hard starting) | mrnickleye | MKIII Supra | 12 | 11-13-2010 08:32 PM |
Testing for bad ECU, &/or bad Fuel Pump | elliotl | MKIII Supra | 0 | 08-21-2007 10:42 PM |
improper resistance ohm testing my afm. | DRIFTINGmy85 | MKII Supra | 1 | 11-30-2006 08:35 PM |
