Old 08-27-2011, 11:27 AM   #1
winnas13
winnas13 is on a distinguished road
Default Noise from the rear end? possibly a wheel??
Hey guys, so when i drive my supra i get this weird noise from the back of the car,
its sorta like the noise you'd expect from a warped disc or something... like a rrra rra rra rra rra noise. Gets quicker the quicker i go. Also when i turn the wheel even a tiny bit to the right it goes away completely, when the wheel is straight and turning left its happening. I went for a drive on the freeway so 110+ km/h speeds and long right hand sweeping corners the noise goes away.
I think it's a wheel issue, like something scraping every time the wheel goes around, or maybe a bearing?
let me know if you need any more info.
It's starting to get louder the more i drive so want to get it fixed! thanks guys.
winnas13 is offline   Reply With Quote
Old 08-27-2011, 07:27 PM   #2
If you've got aftermarket (wide) rear rims, and/or your Supra has been extensively roadraced, it's likely a rear wheel bearing.
Old 08-28-2011, 02:19 AM   #3
Sonyps307
It's a wheel bearing. my brothers mustang was doing the same thing.
Old 08-28-2011, 12:30 PM   #4
winnas13
I think you're right. I hope the supra hasn't been road raced! The wheels are pretty wide though at the rear - Khumo tyres 265/35Z R18 97Y XL (that means nothing to me)
Is a wheel bearing expensive to be replaced/fixed?
Old 08-28-2011, 11:26 PM   #5
Unfortunately, yes. Typically, the hub is removed, the bearing is pressed out, the new one is pressed in, the hub is reinstalled, and then you need a new rear alignment. Not a trivial task.
Old 08-30-2011, 04:29 AM   #6
winnas13
Mechanic came over today. It appears that you can move the whole wheel (side to side) like the hub is loose. We took the wheel off and put a washer behind the wheel nut which wasn't very tight (was as tight as could go) It was almost like there wasn't any thread left to tighten on.
Anyway it didn't fix it, So he is gonna grab a thicker washer, he hopes this will fix the noise. When he comes back tomorrow he's gonna take the whole thing apart and have a good look anyway.
Old 09-01-2011, 06:38 AM   #7
winnas13
Ok so i've managed to source a complete new hub and shaft assembly that was imported from Japan. $275 with a 5 yr warranty.
Old 09-01-2011, 03:47 PM   #8
Hmmm, that seems strange to me. Wouldn't it have been cheaper to just get a brand-new wheel bearing from Toyota?
Also, how would you place a claim if that used wheel bearing fails in 3 or 4 years? I have to wonder if that used parts importer will even still be in business. With a brand new bearing from Toyota, it's less likely to fail AND Toyota will still be around at the end of the warranty period.
Old 09-02-2011, 12:55 PM   #9
winnas13
A new wheel bearing from toyota is $318 plus the two rubber seals at $40 each. Gotta be sent over from interstate. Parts like this are hard to come by in Australia. Gotta go to Jap import stores which are scarce.
So yes i agree that it's a better idea to buy the brand new part, but my mechanic reckons the actual hub has been damaged in the process, which is why i'm going for the 2nd hand one.
Growling or rumble strip noise from rear of car. dlfred MKIII Supra 6 12-02-2010 09:30 AM
Weird noise from rear trevor510 MKIII Supra 2 02-23-2008 08:46 PM
noise coming from rear of car? merryprankster MKIII Supra 2 06-21-2007 02:52 AM
Rusty Rear Wheel Arches Bill UK Non-Generation Specific Questions 1 01-21-2007 10:07 PM
