Old 08-29-2011, 10:23 AM   #1
wcrispino
wcrispino's Avatar
wcrispino is on a distinguished road
Exclamation idling problem
Hi guys long time no see, anyways Ihave a problem you guys can hopefully help me with. My JZA80 n/a 3.0L is idling at around 2000rpms. To me it feels like the choke is stuck on. In the mornings when I go to start the car its revving around 2000rpm, which is normal but if I tap the accelerator the idling goes up and down! Any ideas on what the problem is, any feedback would be appreciated.
Thanks
wcrispino is offline   Reply With Quote
Old 09-05-2011, 04:34 PM   #2
Thanks
You'll need to check for boost/vacuum leaks. One way to do this is to pressurize the system and listen for where the air is leaking. Some shops have smoke they use along with the pressure which makes the leak easily visible.
Sorry for the delayed response. Please feel free to email me if I haven't responded to your post within a day or two. Most likely I just haven't been online, or I might have missed it in the thread list:
pwpanas@gmail.com
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Idling Problem! Dejvid1785 MKIII Supra 22 10-05-2007 12:46 AM
