Old 09-11-2011, 05:08 PM   #1
Mrow
Mrow is on a distinguished road
Default Roll start but no key start. Need help
Have a 95 TT, drove it all the way from CT to NC no problems, stalled it randomly at a stop light on the way back (eye candy makes you stall I guess). Since then it wont start, only roll starts by popping the clutch. Placing the key in and rotating to on I receive what looks like and amber brake light two spaces to the left of the red battery light which is also lit, as well as the large exclamation/warnin light on the rpm meter. I checked to make sure that wasnt due tothe parking brake and it isn't. I also assumed it was the starter but it was previously working flawless and if I'm underthe hood when the key is turned to start I can hear the whine and click from it. At this point now though I'm getting nothing since these three indications have come in. Also when I turn the key to start the lights do fade out on the clock, etc. As if attempting to start. The car alsi has an autopage rs-855 remote start that I wish I knew how to remove because it may be causing the problem. Does anyone have any suggestions? I'm new to supras so if I'm needig to check specific locations I'd need guidance on where to look for exact parts.
Mrow is offline   Reply With Quote
Old 09-11-2011, 06:11 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Perhaps a bad battery and/or alternator? If you can limp it to an auto parts store, they can do a test for you...
Also, this link may help:
http://www.autopageusa.com/t_inside....ion=operations
Lastly, take a look at this link. A turbo timer keeps your Mkiv TT running after you turn off the key. My guess it taps into some of the same wires that a remote start would:
http://www.mkiv.com/techarticles/hks...urbo_timer.htm
Life begins at 30psi.
car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st rjSupra MKIII Supra 41 03-21-2014 05:27 PM
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
