Have a 95 TT, drove it all the way from CT to NC no problems, stalled it randomly at a stop light on the way back (eye candy makes you stall I guess). Since then it wont start, only roll starts by popping the clutch. Placing the key in and rotating to on I receive what looks like and amber brake light two spaces to the left of the red battery light which is also lit, as well as the large exclamation/warnin light on the rpm meter. I checked to make sure that wasnt due tothe parking brake and it isn't. I also assumed it was the starter but it was previously working flawless and if I'm underthe hood when the key is turned to start I can hear the whine and click from it. At this point now though I'm getting nothing since these three indications have come in. Also when I turn the key to start the lights do fade out on the clock, etc. As if attempting to start. The car alsi has an autopage rs-855 remote start that I wish I knew how to remove because it may be causing the problem. Does anyone have any suggestions? I'm new to supras so if I'm needig to check specific locations I'd need guidance on where to look for exact parts.
#2 | |
![]() Quote:
Also, this link may help: http://www.autopageusa.com/t_inside....ion=operations Lastly, take a look at this link. A turbo timer keeps your Mkiv TT running after you turn off the key. My guess it taps into some of the same wires that a remote start would: http://www.mkiv.com/techarticles/hks...urbo_timer.htm
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 09-11-2011 at 06:55 PM. |
car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st | rjSupra | MKIII Supra | 41 | 03-21-2014 05:27 PM |
87 Supra won't start | RNEMESiS42 | MKIII Supra | 3 | 06-25-2011 06:30 PM |
Car wont start hot | carfanatic89 | MKIII Supra | 41 | 03-30-2009 10:58 PM |
Car Died...where to start? | Jrew | MKIII Supra | 4 | 10-26-2007 02:19 PM |
no start | 87supraguy | MKIII Supra | 5 | 03-23-2006 07:31 AM |
