Old 04-11-2012, 03:39 PM   #1
pandrade
pandrade is on a distinguished road
Default installing 4 channel mk4 abs into a mk3
hey every one i usualy post in the mk3 section becuase thats what i have but i started a thead about the stock 3 channel abs. cre recomended i post here and more or less ask phil. i was woundering if you could put a 4 channel into the mk3 if the mk4 came whith one. heres where the discusion started
http://www.toyota-supra.info/forums/...ing-valve.html
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Old 04-12-2012, 06:15 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
I posted a response in the original thread. In short, the MKIV TT did come with a 4-channel.
As to whether or not you could put it into an MK3, the answer is very likely yes, but very likely you'd need to run one or more additional/new brake lines.
Life begins at 30psi.
Need Help on installing a Aeromotive FPRk on a MK3 Turbo turbochargedsupraman MKIII Supra 1 10-08-2011 01:57 PM
Need Help on installing a Aeromotive FPRk on a MK3 Turbo turbochargedsupraman MKIII Supra 0 10-08-2011 07:15 AM
installing thermostat sd88supra MKIII Supra 8 06-18-2010 02:23 AM
installing new intercooler 1_BAD_MK3 MKIII Supra 1 01-31-2010 12:23 PM
question about installing a JDM mad_dicer MKIII Supra 7 11-12-2006 03:21 PM
