Old 11-20-2011, 02:45 PM   #1
yoshi123
yoshi123 is on a distinguished road
Default Car broke down - ODB error codes 14 and 24
Car about 2 weeks ago flicked up an engine light and wouldn't let me go past 2000rpms. Tried to get car to go past 2000rpm few times, then sat behind traffic for 5 minutes, car then ran as normal.
Drove car for further 2 weeks, no problems. Ran sweet as.
Then did a short run 3 miles. Stopped car, did shopping. Then drove back 1/2 mile engine light came on, all other lights came on also. Car stopped dead, power steering stopped working. Tried to re-start, but then cut revs to 0rpm and stalled, all lights on. Tried again after 5 mins, got it about 30 yards then stopped. Called the AA and let car sit for 1h 20mins. AA started car, drove fine for 1 mile. Then we drove back home, 3 miles. No problems.
Did the paperclip method diagnostic - pulled codes 14 and 24.
Code Description Causes
14 Ignition Signal Circuit
Open or short in IGF circuit from ignitor at ECU
Ignitor
ECU
24 Intake Air Temp Sensor Circuit
Open or short in intake air temp sensor circuit
ECU
The car has a TOMS ECU and a MPH converter attached, stock twins, boost controller Blitz.
Should be worth noting I had a rad failure about 3 months ago, fluid all over the engine bay. I am not sure if this has had some effect, e.g.corroding some connector or something.
As far as I can see it's either intake Air temp sensor, Ignitor or ECU.
Ignitor symptoms seem to be car won't start - my car starts fine but randomly dies. Not sure if this is the issues.
My plan of action is to look is to trace the wires back to the ignitor (where is this btw?).
Otherwise, please help with some suggestions to fix.
yoshi123 is offline   Reply With Quote
If it ain't broke don't fix it vbryanv MKIII Supra 3 04-04-2011 05:39 PM
oops i broke the headlight help supraluver4life MKIII Supra 13 12-22-2009 04:04 AM
Speedo cable broke. What next? Busted Knuckles MKIII Supra 5 10-25-2009 06:01 AM
Broke something.. and i dont know what it is. help. Kevin MKIII Supra 2 06-08-2009 12:10 PM
my 86 broke pittsupra MKII Supra 2 06-05-2006 11:42 AM
