Old 12-15-2011, 02:10 PM   #1
kawboyz2002
kawboyz2002 is on a distinguished road
Default Worried about wheel rubbing issues
Hello everyone, I have a 1994 N/A Supra on stock suspension and im considering buying some wheels for it. The specs are as follows: 19x9.5 front +22 offset 19x11 rear +25 offset with 73.1 bore. I wanted to know if anyone on this forum has ever ran this setup and if there were any issues as far as rubbing? Also what size tires would be recomended? I'm trying to get a real aggressive look in the rear without having to do too much modifications. I already had my rear fenders rolled before i had the car painted. thanks....
kawboyz2002 is offline   Reply With Quote
Old 12-15-2011, 10:50 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Those offsets sound wrong to me. I believe the oem offsets are +50mm...
Also, tires that wide are a huge waste on an n/a, imho.
Life begins at 30psi.
Old 12-16-2011, 05:40 AM   #3
Codyjamesuno
19 is a big wheel, i like the look of 18's the best, still can get a meaty tire then, but to each his own, what ever you do, post some pictures of it!
Old 05-20-2013, 02:17 PM   #4
kawboyz2002
I sold the wheels and tired to a friend with a 350z. Looks sick on his car. I think im gonna go with the 18's. Found a set of wheels that are 18x9.5 +40 in the rear and 18x18.5+35 In the front. What's the widest tire I can get on there? Also do you think these will sit flush with the fender?
Old 05-20-2013, 07:32 PM   #5
pwpanas
Supra Owner
pwpanas's Avatar
With a trimmed (not rolled) rear fender lip, you can fit 315-width rubber on 11.5" width rims.
Old 05-21-2013, 11:26 PM   #6
Codyjamesuno
Default offset issues ,
I just put these on my Supra a couple of months ago, but be aware of this, get the right wheel fitment for the supra, aka the right offset, just cause they say they will fit doesn't mean they fit correct, i love the look of my new wheels, but they have been a pain in my ass, I have coil overs and have to take it in to get raised again, or I have to roll the fenders because my offset is not right so the new wheels stick out further then they are supposed to. I don't know what I should do I can get you the offset i have so you don't make the same mistake i did, but I agree wide wheels on a N/A is kind of beating a dead horse.
ID:	4820   Click image for larger version
Old 05-22-2013, 03:39 AM   #7
kawboyz2002
Thanks, that would be greatly appreciated. I was about to pull the trigger on another set of wheels but honestly I'm scared of getting some with an incorrect offset and the wheels won't look the way I want.
Old 05-23-2013, 02:26 AM   #8
pwpanas
Supra Owner
pwpanas's Avatar
...have to take it in to get raised again, or I have to roll the fenders...
Seems like I've posted this a dozen times: trim the fender lips - don't roll them!!!! Rolling them is a big mistake.
I've tried it both ways. Learn from my mistakes. I've personally trimmed several Mkiv Supra rear fender lips and they always come out great. There's literally no downside whatsoever to trimming, and many unique benefits. It's relatively easy. Your fender won't warp. You can do it yourself. No expensive tools required (eg. you can do it with a $20 jigsaw from a hardware store, if you follow the right prep and cutting process). Your fender will be just as strong as it was before. Please PM me if you have any concerns at all or if you have any questions about how, what tools, prep, process, finishing, etc.
Noise from the rear end? possibly a wheel?? winnas13 MKIV Supra 8 09-02-2011 12:55 PM
Momo steering wheel , working horn and returning indicator stalk Gunnar MKIII Supra 0 03-28-2010 09:41 AM
Having Trouble Removing the Steering Wheel Chambers MKIII Supra 3 06-30-2008 01:03 AM
Aftermarket steering wheel RTZ MKIII Supra 10 02-07-2008 08:44 AM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
