Old 03-21-2012, 12:51 AM   #1
John Trip
John Trip is on a distinguished road
Default Info on Supra MKIV european version
I'm currently looking to buy a supra MkIV the european version with the 2JZ-GTE engine and twin turbo's but I've hit an obstacle I was told that when looking at the engine tag to look for R-JZA80-ALMVZ (as the R stand for European Export), but a yahoo search finds nothing for this code, I want to make sure that this information is correct or incorrect before I proceed. Thanks.
John Trip is offline   Reply With Quote
Old 03-21-2012, 07:27 AM   #2
Please try to post in the correct section. In most cases it should be obvious but if you are unsure each sub-forum has a description which you can read from the main directory. This obviously belongs in the MKIV section, not "non-generation specific" and definitely not in any of the FAQ sections. I'll move this to the MKIV section for you.
Old 03-22-2012, 12:58 AM   #3
Sorry I don't have info on this, but Toyota might. I'd suggest you call Curt Aigner at Elmhurst Toyota. Please PM me if you can't find the phone number...
Old 03-22-2012, 10:57 PM   #4
John Trip
This is the link to the page that my mate read about the R code it's near the top under "Engine Tag Information".
http://mkiv.supras.org.nz/specs.htm
Want to learn about the Mkiv Supra? pwpanas MKIV FAQ 6 09-06-2008 05:37 PM
