Old 04-02-2012, 07:12 PM   #1
livestrongroadie
livestrongroadie is on a distinguished road
Default Anyone with Tanabe Concept Blue?
I am about 90% decided on purchasing the tanabe concept blue system but want some input from anyone who has one or who has had one. Is it a descent quality and does it give a nice tone? On a scale of 1 to 10(one being stock) how loud is the system? Im just trying to figure out if its worth the money.
My runner up right now is the apexi gt spec, but not to sure on that one either.
Any input would be appreciated, but i mostly want feedback on the tanabe as i am pretty much set on that one unless someone has some extremely negative experience with it.
livestrongroadie is offline   Reply With Quote
Old 04-03-2012, 10:05 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
What are the other mods on your Supra? Are you bpu++++? Single turbo?
Life begins at 30psi.
Old 04-04-2012, 12:39 AM   #3
livestrongroadie
I am currently bone-stock N/A but am doing a JDM VVTi TT swap sometime in the near future which is another reason i am considering this system. I can use the cat back portion on my current setup, then when I do the engine swap, I can install the rest of it since I would need different down and mid pipes anyway.
I know that it is a bit more difficult to get a good tone out of a straight six than a V-six, and I am willing to compromise a bit, but I just dont want a setup that comes out "ricey".
Old 04-04-2012, 04:05 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
  1. I believe you can use the same midpipe after the swap. Not 100% sure, but it's very likely.
  2. I'm also pretty sure that your 'cat back portion' is the same for both the n/a and the TT. Regardless, please note that the oem TT exhaust works just fine for stock boost levels with the oem twins, as well as BPU.
    In other words, the oem TT exhaust is not a restriction, and you will get no horsepower increase using an aftermarket exhaust.
  3. Good tone from a v-six? Gosh. I've heard of folks talking about "good tone" from a big-block V8, but a v-6? Weird...
    Fwiw, to me, any v6 sounds noticeably worse than any I-6 (especially a 2jz).
  4. When you're pushing a lot of horsepower and winning races, no one really cares what your car sounds like...although with all the extra exhaust generated with race fuel and big boost, it can't help but sound good too.
    About the only way to get a "ricey" sound, imho, is to put an open (i.e. loud) exhaust on any low-horsepower n/a (that includes low-horsepower V8s). *shrug*
  5. To me, the only reason to put an aftermarket exhaust on a stock TT or BPU Supra is for looks. If that's your deal, I understand completely...don't want to be parked next to the guy at the car meet when you've got a relatively small tailpipe. Chicks dig big tailpipes (so I hear). However, if that's all you're looking for, just take a short 4" pipe and/or transition, cut it on an angle, get it polished/chromed, and get it welded onto your oem exhaust. You can even get tips pre-chromed. Either way, it'll be a lot cheaper.
Help me!!! imseeinred Exterior , Interior, and Detailing 2 10-20-2010 07:01 AM
tokico blue shocks and tanabe springs 7mge(for now) supra MKIII Supra 0 08-24-2009 10:26 PM
Blue Smoke turbomk529 MKIII Supra 2 08-14-2008 02:25 AM
What does the blue sensor do? justin1642 MKIII Supra 6 06-19-2007 12:21 AM
[Photoshop] New Concept C.44 MKIII Supra 4 01-10-2006 11:24 AM
