#1 |
I have been looking at some turbos and I came across what looked like a good turbo but Id like to know what you think. I am looking for a good 650whp turbo that has the quickest spool time I will also be running methanol in the car. This first turbo is the turbo that was reccomended to me along with a kit that I would substitute the turbo out for this one. The second turbo kit is the one I found on my own and it seems pretty promising. Let me know what you guys think, I will be purchasing it at the beginning of the summer. The second turbo kit is the Powerhouse racing Stage 1 turbo kit with the dual ball bearing turbo
http://www.spracingonline.com/store/...urbo_6262/3663 http://www.mvpmotorsports.com/Templa...211&SearchYN=N |
#2 | ||
Supra Owner
![]() Quote:
2) That PHR stage 1 kit is a 630rwhp kit (not 650rwhp), and same as my previous point, they likely ran a lot of boost with race fuel to get it. Probably about 30psi, I'd guess...which is significantly more boost than most meth injection kits can handle. Are you willing to supplement the octane of your methanol injection with race fuel in your primary fuel tank? Please remind me - are you going through a 6spd or an auto tranny? My recommendations: 1) Get both the turbo and the kit from the same supplier (eg. Sound Performance). 2) Regardless of which supplier you choose, pick a slightly larger turbo, so you won't have to run as much boost to get 650rwhp. Sure, it'll lag a little bit more, but at least your engine will stay in one piece! I'd recommend something with approximately a 66mm or 67mm inducer. 3) The exact turbo honestly doesn't matter that much. Really! Anything with approximately the same inducer diameter and turbo design will spool roughly the same. You really won't notice a couple hundred rpm up or down while driving (a couple thousand, sure...but to get that big a difference, there's no way the turbo is the same size). After you square away your turbo upgrade, there are so many other things to worry about (eg driver training, tuning, traction, braking, driver training, precise boost control, etc., etc. (did I mention driver training? ![]() Lastly, please remind us of your application? (i.e. drifting, daily driving, top speed, autocross, drag, daily driver, roadracing, burnout contests, etc.) If you're going to be running your Mkiv Supra in a professional competition, then sure - perhaps 100rpm of spool time would be relevant...
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 04-27-2012 at 01:50 PM. |
#3 |
I am going to be running methanol injection (snow performances stage 3 kit) and I will primarily be daily driving it, road racing, and the occasional drag racing. I just need a good turbo that has a quick spool time. I have been looking at sound performances turbos because along with the turbo I could buy their quick spool valve to go with it. So basically I want to buy a full turbo kit with the fastest spooling turbo that will get me roughly 650whp.
#4 | |
Supra Owner
![]() Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#5 |
Ok that's makes sense. Could you post a link to a turbo or turbo kit that would be best for my hp goal and application? I would run race fuel but its just so expensive and I'd rather just run methanol since a one gallon tank of meth injection will last longer then a tank of race fuel.
#6 | |
Supra Owner
![]() Quote:
Consider this complete turbo kit. If you get it tuned properly (including precise boost control), I'm certain you'll be happy with it: http://www.spracingonline.com/store/...93-98_Supra/28 Pick the .81 a/r and ball bearing (with water lines) options.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 05-05-2012 at 01:23 AM. |
Was there ever just a single turbo supra every built. | MarkN10 | Non-Generation Specific Questions | 6 | 12-05-2011 02:46 AM |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
Did they make an original single turbo supra (1994)? | ts1994 | MKIV Supra | 3 | 07-20-2006 08:18 PM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
Turbo lag question. | rnoswal | MKIII Supra | 6 | 02-12-2006 05:42 AM |
