Old 09-19-2012, 01:45 PM   #11
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Travis89Turbo View Post
Okay. I installed an aftermarket Aeromotive regulator with steel braided lines set within factory specs.
All seemed great yesterday afrs were where the should be around 14.7 so I parked it and then while driving to work this morning guess what came back! The lope in the idle.
Agghh. The CEL did come back on and I will be checking that at lunch time and will update that info. I have no idea what's goin on.
Is it possible my headgasket is seeping? Although I am not missing fluid.
I put some new fuel in it with some injector cleaner so time will tell of that helps at all.
Per my post above, have you checked for boost/vacuum leaks yet via pressurizing the intake yet?
One potential issue is a split vaccum (or charge air) hose that weakens with heat. A boost leak check will detect this (and an ordinary smoke test won't).
Here's another thought (while we're on the topic of split hoses):
http://autos.groups.yahoo.com/group/mkiv/message/230604
Life begins at 30psi.
Old 09-19-2012, 02:10 PM   #12
Travis89Turbo
Travis89Turbo's Avatar
I have not yet pressurized the system I will do that this evening after building an adapter.
I pulled the code ==== 25 lean condition?? Fuel pressure is within spec.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 09-19-2012, 06:03 PM   #13
Travis89Turbo
I am starting to think possibly a bad MAF. I am running out of money fast throwing parts at it. Do you kno how to test the MAF on a ge??
Also at lunch today the check engine light went out on its own. At times my afr are perfect idling at 13.9 then all of a sudden just fall on its face down to 16-17. I unplugged the maf and it did not change the way it was missing???
I am also goin to ohm out the injectors this evening as well.
stock 2jzge
Old 09-20-2012, 09:40 AM   #14
pwpanas
Supra Owner
pwpanas's Avatar
The easiest way is to swap it out with another Supra. I agree this is a possibility. One of my Supra buddies did have a MAF go bad.
Do you have the TSRM? I know it's a few bucks, but it's money well-spent that will pay itself back over and over again. The MAF test procedure and thousands of other useful procedures are detailed in it.
Old 09-20-2012, 12:30 PM   #15
Travis89Turbo
I do not yet have one but do plan on buying one.
Update- I pulled the turbo system off and put the stock na header back on with the sane 4runner dist cap and msd wires. Car runs AMAZING so far it made it all the way to work and didn't skip a beat for the first time in a while!
So two things I'm goin to do. In order to run my afr gauge I am only running one o2 and jumped the wires for the second into it. I am goin to switch it to the rear bank after work to confirm I ge the same results. If I do then I will be doin the pressure check on the intercooler piping. If that checks out the I will install the turbo and check it through the intake of turbo pressuring the entire system.
My question to you is should I dis connect it at the throttle body or will it hold 50psi??
stock 2jzge
Old 09-21-2012, 01:19 AM   #16
Travis89Turbo
Update
I switched the o2 sensor to the rear bank and what do ya know it started acting up again stumbling on idle just like before afrs drop lean.
So I ohm'd the injectors they all checked out within limits.
So tomoroow I will be gettin a new leak down tester and an adapter for my compression gauges as I didn't receive it back after I loaned it out.
Fluid levels still look great. No mix in any fluids so I am starting to wonder about my piston rings. ??
stock 2jzge
Old 09-21-2012, 02:35 AM   #17
pwpanas
Supra Owner
pwpanas's Avatar
...My question to you is should I dis connect it at the throttle body or will it hold 50psi??
Everything should hold about 50psi bone cold. This is the equivalent of about 25psi running hot under boost. If things pop apart at 50psi or less, it just means you need better t-bolt clamps & couplings.
Old 09-21-2012, 02:37 AM   #18
pwpanas
Supra Owner
pwpanas's Avatar
Update
Maybe a silly question, but if it runs great using the O2 sensor to the front bank then maybe the problem is related to the rear O2 sensor (i.e. not anything else like the piston rings)?
Old 09-21-2012, 11:38 AM   #19
Travis89Turbo
I used the same o2 sensor for both tests just switched locations with my wideband afr.
I did a pressure check on the intercooler and piping but with the turbo pulled off I couldn't do it through the intake of the turbo yet.
Could still possibly be a clogged injector but the compression test will let me kno that tonight.
If it is rings I won't be rebuilding the GE. The limits are so tight on these motors I don't trust it with just a plasti gauge and don't have any better or special tools for that. So I will be looking into a 2jzgte swap with my single on it and pull the jdm twins. But would much rather not have to do that. Hopefully its not a compression issue in the bottom end. I will keep you posted!
stock 2jzge
Old 09-21-2012, 01:18 PM   #20
pwpanas
Supra Owner
pwpanas's Avatar
I used the same o2 sensor for both tests just switched locations with my wideband afr...
Okay, but which O2 sensor was the oem ecu using to regulate the a/f curve? Since it ran fine when you flipped the wideband...
  1. Quote:
    ...I pulled the turbo system off and put the stock na header back on with the sane 4runner dist cap and msd wires. Car runs AMAZING so far it made it all the way to work and didn't skip a beat for the first time in a while!...
  2. Quote:
    ...I switched the o2 sensor to the rear bank and what do ya know it started acting up again stumbling on idle just like before afrs drop lean...
...then it seems that troubleshooting should focus on something to do with the O2 sensor?
If this is a dumb suggestion, please ignore. It's REALLY hard to provide third-hand advice over the internet...
88 non turbo wont idle down SupraGuy91 MKIII Supra 1 10-17-2012 11:07 PM
Rough idle on warm start up (20 minutes), 87 7MGTE Bru MKIII Supra 10 05-11-2012 12:27 AM
idle surging up and down when warm hemi34 MKIII Supra 1 09-29-2010 04:20 PM
Need help identifying a part and thought on a miss at idle --WAS: newbie milc80 MKIII Supra 8 06-28-2010 12:53 PM
idle problems 88 supra turbo MKIII Supra 14 03-13-2010 03:43 AM
