Old 07-01-2013, 02:14 PM   #1
gillian
gillian is on a distinguished road
Default drivers seat
hi , i have a problem with my drivers seat, supra 1994...its been iffy for a while , but today it stopped going backwards...will i be able to mend it or will i need a new motor or even a new seat ,,thanks any advice is welcome ..
gillian is offline   Reply With Quote
Old 07-06-2013, 06:03 PM   #2
Thread moved to MKIV section.
Old 07-07-2013, 09:24 PM   #3
pwpanas
Supra Owner
pwpanas's Avatar
I believe your least expensive route may be to look for a used seat, complete with motor. Alternatively, you could get a new power seat motor from Toyota, if that actually is the problem.
Just curious - do you hear the motor trying to work if you try to make it move forward? This may indicate whether or not the motor itself is still working (i.e. perhaps the problem is not with the motor).
For example, the problem might (in theory) be the switch that indicates the seat is in the fully-back position. If that sensor has failed in the closed position, it could cause the rearward position of the seat forward/back switch to not work. That sensor, even brand new from Toyota, is likely quite inexpensive...if you're really lucky, perhaps this is the issue.
Life begins at 30psi.
Seat trouble xThermoNucleaRx MKIII Supra 2 08-15-2012 08:24 AM
Non-power driver's seat? 907mge MKIII Supra 2 07-31-2012 05:20 AM
Jdm RHD seat for LHD passanger seat?? Travis89Turbo MKIII Supra 4 05-11-2011 06:01 PM
Electronic drivers seat?... *D-Joker* MKIII Supra 2 08-27-2009 01:01 AM
Seat Covers SupraTaylor MKIII Supra 0 04-27-2009 05:39 PM
