Old 10-26-2013, 04:24 PM   #1
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Default 2jzgte not making power...?
Hi everyone.
I need advise we installed a 2jzgte motor in an e46 M3 but it's not making power as soon as it gets to 5800 RPM the power drops.
List of mods done.
Running a powermod ecu
Stock bottom..gasflowed head,cams cut same place as mine split duration 268 ex and 272 intake.
Turbo T72 .68 Exh Turbonetics. Same Exh manifold as mine cheap.
Turbosmart wastage 45mm..
50 mm dump valve.
Fake Greddy intake manifold.80mm throttle.
750cc injectors.
Cometic low comp gasket with arp studs.
76mm downpipe with 76mm Exh.
It made like 240kw and 400nm something is wrong....?????????
warmkop is offline   Reply With Quote
Old 11-19-2013, 02:54 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
Hi everyone.
List of mods done.
50 mm dump valve.
750cc injectors.
Can you post a dyno run with air-fuel and boost plotted together with horsepower and torque?
Life begins at 30psi.
Old 12-08-2013, 08:16 AM   #3
warmkop
Moderator
warmkop's Avatar
So on the 2j that's not making power they changed the turbo they say there was something wrong with the turbo will see when it goes for a dyno will let you know as soon as I know.
need help making power 94tt warmkop MKIV Supra 185 10-05-2014 01:52 PM
Aftermarket shifters for R154 trans MKIII? Boombastic Exterior , Interior, and Detailing 4 08-11-2010 04:28 PM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
