#1 |
Moderator
Hi everyone.
I need advise we installed a 2jzgte motor in an e46 M3 but it's not making power as soon as it gets to 5800 RPM the power drops. List of mods done. Running a powermod ecu Stock bottom..gasflowed head,cams cut same place as mine split duration 268 ex and 272 intake. Turbo T72 .68 Exh Turbonetics. Same Exh manifold as mine cheap. Turbosmart wastage 45mm.. 50 mm dump valve. Fake Greddy intake manifold.80mm throttle. 750cc injectors. Cometic low comp gasket with arp studs. 76mm downpipe with 76mm Exh. It made like 240kw and 400nm something is wrong....????????? |
need help making power 94tt | warmkop | MKIV Supra | 185 | 10-05-2014 01:52 PM |
Aftermarket shifters for R154 trans MKIII? | Boombastic | Exterior , Interior, and Detailing | 4 | 08-11-2010 04:28 PM |
getaway in stockholm... (i think thats how you spell it) | kelogg | Road Racing & Autocross | 3 | 06-03-2008 10:53 PM |
Before buying an 85 P Supra with 123k what to look for | e30cabrio | MKII Supra | 0 | 02-24-2008 08:09 PM |
MEET UP's | TEAM_Bastos | Drifting | 0 | 03-02-2006 09:09 PM |
