Old 03-01-2006, 08:42 PM   #1
kenshi1023
kenshi1023 is on a distinguished road
Default Mid Engine 1jz/2jz project
I did some searches before posting, couldn't find anything on converting a 1jz or 2jz to a mid engine layout.
my question is can a 5sp solara tranny be mate with a 1jz or 2jz motor, so that it can be put into a mid engine design layout. are there other trannies that can be use for this purpose. thanks
kenshi1023 is offline   Reply With Quote
Old 05-17-2015, 07:50 AM   #2
Jackal101
Jackal101 is on a distinguished road
Default Mid engine 2 jz
I used an Audi 01e six speed box mated to a 2jz-gte. Costs ran +/- $1500 to mate the two. That included custom flywheel, custom adapter plate, custom clutch (3 pack), custom release bearing housing. I will be picking it up on Monday from the Engineering shop.
Car is based on Lambo Murcie but with my own tweaks. Side intakes added Celica headlights, Still have to pull the mold for the body and then do the body.
Jackal101 is offline   Reply With Quote
Old 06-05-2015, 06:59 AM   #3
Jackal101
Here is my 2jz-gte mated to an Audi 01e 6 speed transmission.
Old 06-27-2015, 03:54 PM   #4
pwpanas
Supra Owner
pwpanas's Avatar
Nice! Did you make that custom adapter plate yourself? If so, can you tell us anything about how you did it?
Life begins at 30psi.
Old 06-29-2015, 06:30 AM   #5
Jackal101
Hi. No I did not. I had it made at an Engineering shop close by. New Engineering. They also made a custom flywheel and custom 2 pack clutch. (3 pack wouldn't fit and I did not want them to cut on the box itself. 2 pack is good for 1000bhp though)
My friend is doing my chassis here is a pic or two.
Cheers
Name:	Chassis - Vigi.jpg
ID:	4947   Click image for larger version
ID:	4950   Click image for larger version
Name:	Chassis - Vigi3.jpg
ID:	4948   Click image for larger version
Old 06-29-2015, 06:37 AM   #6
Jackal101
Here is a better pic of the adaptor plate and flywheel and also a pic of my body I am doing
Name:	Vigi flywheel.jpg
Engine Project nelly26 MKIII Supra 0 10-26-2006 11:25 AM
