Recently this week my 93 supra tt auto started to not rev pas 3rpm after it shifts from the first gear.On the first gear i am able to get to 7rpm but after that it doesnt rev past 3 rpm. It feels like i would have a cut off or it goes on limp mode. My dad is coming to scan for codes but i wanted to know if somone had a problem like that before. My upgrades are straight pipe FMC and intake and blitz blow off. Any help is much appreciated. Thank u
#2 | |
![]() Quote:
To troubleshoot, just pressurize your entire charge-air system to about 20psi. You'll hear the leak.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 07-10-2015 at 09:49 PM. |
Thanks for the reply well scanned my codes had a code 42 fixed that one. But then had a code 64 from my tranny wich means solenoid valve 2, ECU, or short circuit. checked both my solenoid they both worked now its my ecu the problem or my wiring.
#4 | |
![]() Quote:
You should be able to use a multimeter to diagnose any other issues with the harness/wiring.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
Ok thanks a lot will do and ill post back when I find what it was. Thank u for the help
wont go past 2,000 rpms in any gear... HELP! | Preston | MKIII Supra | 2 | 06-10-2011 01:52 PM |
harmonic balancer came off crank shaft help? | wishiknewmore | MKIII Supra | 3 | 04-15-2011 11:04 AM |
turb boost increase every gear | john_lauj | MKIII Supra | 3 | 09-29-2010 02:08 AM |
1st gear jumping out, 4th gear crunching, how do I fix it without changing gearbox | wcrispino | Non-Generation Specific Questions | 7 | 01-31-2010 11:13 AM |
quick question | blacksheep | Non-Generation Specific Questions | 10 | 01-01-2007 08:19 PM |
