Old 10-24-2005, 07:59 PM   #1
unclebenny
unclebenny is on a distinguished road
Default stock fuel pump replacement
Where is the best/cheapest place to buy a stock fuel pump? I just wanted to know if there's a club discount or anything before I pay the stealership $220.
Thanks,
Eric
unclebenny is offline   Reply With Quote
Old 10-24-2005, 11:45 PM   #2
unclebenny
I would really appreciate any info....
Old 10-25-2005, 01:19 AM   #3
TRAFIK
TRAFIK's Avatar
TRAFIK is on a distinguished road
TRY LOOKING IT UP IN http://www.trademotion.com/partlocat...?siteid=213747
WWW.ROCKAUTO.COM
TRAFIK is offline   Reply With Quote
Old 10-25-2005, 02:41 AM   #4
unclebenny
Thats still $210....
No one has a club discount or anything to get it cheaper than that??
Old 10-25-2005, 01:16 PM   #5
FYI: You can get a new Walbro high pressure, high flow, drop-in replacement for the oem TT mkiv Supra pump (complete with rubber base/adapter, sock filter, etc.) for approximately $100 or so...
Old 10-25-2005, 04:59 PM   #6
unclebenny
I didn't know that walbro made one. Thanks for the info. One question though, does it flow the same being half as much money?
Old 10-26-2005, 02:03 AM   #7
supra_91
supra_91's Avatar
yes it will
Old 10-26-2005, 12:34 PM   #8
SupraMan1784
a walbro should flow the same if not better...you want better...so hope for better flow...which you should get
Now: Saving for an MKIV
Broken Rides:
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Stock Fuel Pump..how many LPH?? recomendations christutecky MKIII Supra 2 06-19-2006 03:42 PM
1JZ-GTE Engine with 7mge Stock Fuel Pump joolhamdi MKIII Supra 1 06-10-2006 10:29 AM
