Old 03-26-2006, 11:54 PM   #11
razerback121
razerback121 is on a distinguished road
The Sad truth.....
I recently purchased a JDM 2JZ-GTE Rated @ 280 hp. I was going to leave the engine J-spec because.....its easier like that to just drop it in. Unfortunetely there are no connecters that go from the engine to the Engine bay fuse Box. Furthermore there is a connector on the harness that does not fit anywere onto the Us-Spec supra. This connecters consist of some 60 wires.....Also 2 of the 3 connectors to the ECU are present on the wireharness. The third either connected another ecu or was just imbedded in the j-spec body.
It looks like im going to return the engine to the JDM depot or cought up around 6 more g's to get the engine stripped down and rebuilt to US-spec. I got lots of pics of it if anyone wants to see. I assure though, to the average mechanic its hopeless.
razerback121 is offline   Reply With Quote
Old 04-02-2006, 02:27 AM   #12
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by razerback121
The Sad truth.....
Please do post the pictures.
I'd also mention that the VAST majority of JDM 2jz-gte's available for sale in the US are from Aristo's (and not from Supras). As a result, there are a few physical differences between the two engines, including the oil pan.
I agree it's a tough project, but doable for a good shop experienced in Mkiv Supra Turbos. For example, I've personally seen a number of these completed Mkiv Supras with US NA->JDM TT from AAP Motorsports in Atlanta, Georgia, US. Again, it's doable but I agree it's far from an easy project.
Life begins at 30psi.
Old 04-06-2006, 04:11 AM   #13
razerback121
Know any good shops in the California bay area? Im thinking about taking my car to this guy from Supracharged.com. He has done multiple j2z engine swaps aswell as 7m's. Sp-Engineering gave me a quote for 17,000 for parts and labor which is frightening. I just want it done correctly while at the same time not losing a few arms and a leg.
Old 04-07-2006, 12:26 PM   #14
pwpanas
Supra Owner
pwpanas's Avatar
Unfortunately, I don't have any information about Supercharged.com. Fwiw, I'd advise you to ask them for references of Mkiv Supra Turbo owners that you can call. What area of Cali are you in? I know of a great place in the Sacramento area that would likely give you a better price than that.
Old 04-11-2006, 06:21 PM   #15
razerback121
Bay Area, Fremont, close enough to sacramento. The guy from supracharged, has swapped 2jz's and 7m's into Tacoma's and 4runners. Considering they werent meant for those trucks, I give the guy props and think that meybe putting a GTE into a NA wouldnt be too hard for him. Lemme know what info you got about this shop in Sacramento though. Thanks!
Year to Year MGE Swap changes Mr.Bojangles MKIII Supra 6 01-10-2008 07:44 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
to swap or not to swap edelmar417 MKII Supra 16 04-10-2007 12:06 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
MKIV auto to manual swap?? awd4g63tsi MKIV Supra 0 10-24-2005 08:46 PM
