Old 11-16-2005, 10:11 PM   #1
tex1116
tex1116 is on a distinguished road
Default Engine noise car wont stay running
I have 88 supra turbo. I recently made a post about car not starting with possible starter issues. The starter still may be a problem but today I was able to get it to crank. It seemed like a rather fast cranking and it wasnt starting so i took off the front engine cover and peeked in to see if the timing belt was broken but it looked fine. Then i inspected the spark plugs which looked pretty oily around the center electrode and appeared to have a significant amount of oil in the spark plug holes(is that normal, it was enough to see my reflection). so i wiped a couple off and reassembled and when to start the car again. There was signs of life but still no starting. I kept at it for awhile and tried starting with the accelerator pressed in which within a couple seconds brought the car to a pretty shaky start. I kept the accelerator pressed in at around 1000-2000 rpms and i could here some pretty disturbing noises from the engine like rapid dull thuds and tapping and as soon as I released the gas petal it died. I tried it a few times to the same effect. Any ideas?
I also just realized this is the wrong forum, but still any help would be appreciated
tex1116 is offline   Reply With Quote
85 engine noise long-cat MKII Supra 0 12-03-2008 08:02 PM
HELP! My engine just started a weird noise... idoke MKIII Supra 12 10-05-2006 05:06 PM
Engine not running to well... Nickss454 Non-Generation Specific Questions 0 09-05-2006 11:55 AM
clicking noise from engine Chomper Non-Generation Specific Questions 6 11-22-2005 04:09 AM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
