#21 |
whats with this 20-40PSI talk.. why do you care so much getting an riduculas amount of PSI on such a crappy turbo.. also to get that much PSI you will have to run high octane race fuel
do where the supra shines.. slap on one big turbo and gun it on the run.. just my 2 cents |
#22 | ||||
Supra Owner
![]() Quote:
Btw, upon further research, it turns out that SKILMATIC was misinformed about yet another item - the 2jz-gte's oem twins are CT12B turbos (not CT26s). Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 12-30-2005 at 07:20 PM. |
#23 | ||||||||||||||
![]() Quote:
Again I have never said in my first posts about any cost boundaries. Find this and I will admit I was wrong. Quote:
#24 |
7M POWAH! ;)
oh damnnn i thought someone wanted to stick 2 ct26's on their 2j.. i didn't realise someone was under the impression they were stock
ct26 from the 7m is superior to the 3sgte ones steel shaft slightly larger
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
#25 | |
![]() Quote:
Then he finally realized that his supposed mk4 didnt come with ct26's stock but rather c12's. This is all kinda fishy to me seeing as pwpanas supposedly owns a mk4 and has built severla bpu's and all the sudden dicovered that his stock twins werent ct26's. I simply let flamers dig their own ditch. It works everytime. |
#26 | |||
Supra Owner
![]() Quote:
![]() Fwiw, my own Supra no longer has ct12b's, since I've upgraded to a single turbo. Here's some more 'education' for you: when you upgrade an Mkiv Supra Turbo, there are only two reliable choices: you either max the oem twins (bpu), or you chuck them out (apu). After hundreds of unsuccessful attempts by Mkiv Supra owners, it's been determined that there's no reliable way to upgrade the ct12b's to anything larger, using the 2jz-gte's ct12b housings. The shaft is just too thin to support bigger wheels. Now that I've clued you in to what they are, you now call the oem twins ct12b's. I simply call them too small. ![]() Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 12-31-2005 at 07:43 PM. |
#27 | |||||||||||||||
Supra Owner
![]() Quote:
A turbo is a simple device. The exhaust spins one side, which powers the simple air compressessor for the intake side. That's it!!! Quote:
![]() Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 12-31-2005 at 07:49 PM. |
#28 | |
Supra Owner
![]() Quote:
http://www.toyota-supra.info/forums/...27&postcount=5 If I were to guess why his math was so off-base when he came up with his 650rwhp figure, it could be partly due to his mistaken impression that the 2jz-gte's stock twins are ct26s...
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 12-31-2005 at 07:41 PM. |
#29 | |||||
![]() Quote:
#30 |
I don’t really want to get into this hp battle (although very informational).
But I really don’t see the stock twins pushing that much psi and rwhp. It’s not impossible but who the hell would want to stress the car so much? Pushing the stock tt limits it’s not good even with bpu's. I would probably start thinking of single or bigger tt upgrade around 500. Just my $0.02 Just for my info…anybody who is running stock twins, How much are you pushing? What is your limit? Where would you say “No More”.
![]() --===Give me 2jz-Gte or give me death!===-- |
Thread Tools | |
Display Modes | |
Boost and Stock Fuel | collink | MKIII Supra | 5 | 03-26-2008 11:43 PM |
1986.5 STOCK SWAP TO A SHORT BLOCK | DarkRaiderz | MKIII Supra | 2 | 06-20-2005 11:59 PM |
