#1 |
I'm new to this forum and not very informed on Toyota Supras I'd like to know what if any horsepower difference there is between the "American" Toyota Supra Twin Turbo(being the ones sold in USA) and the "Import" Toyota Supra Twin Turbo(being the RHD Supra), if I remember correctly the American Supra is rated at 320hp. and are the stats posted on most sights correct for quarter mile time stock for the domestic Supra being around 13.6 seconds? I'm looking into getting a supra in the future and would like to learn more about them and find out how accurate this information is.
#2 |
http://mkiv.supras.org.nz/specs.htm
I belive the export supras had bigger injectors and steel turbos.
![]() --===Give me 2jz-Gte or give me death!===-- |
#3 |
7M POWAH! ;)
the rhd mk4 has 440cc injectors, ct12b turbos (ceramic) 280bhp
lhd mk4 has 550cc injectors, ct12b turbos (steel) 320bhp simple enuf ![]()
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
#4 | |
Supra Owner
![]() Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
#5 |
really the RHD Toyota Supra has less horsepower? I always thought that Imported cars were higher horsepower :S apparently I'm wrong. thanks for the info tho.
#6 |
btw I'm told that you need to put alot of money into a supra to ACTUALLY be able to run a 13.6second in the quarter mile is this true? or are they just people that think they know something and like to talk out their butt? lmao
#7 |
A lot of money to run 13.6.?
NO! Thats like STOCK or slower then stock.
![]() --===Give me 2jz-Gte or give me death!===-- Last edited by TRAFIK; 01-02-2006 at 07:55 PM. |
#8 |
oh maybe that 4.9 and 13.4 were from another magazine. when trying to find it, i ran into the car and driver one and it says 4.6 and 13.1... so i guess it depends what day of the week it is. anyways, cool r&t articles
http://www.geocities.com/ma71supratu...93cdsupra.html and here's a site any supra fan would like because it has articles for all mk's http://www.geocities.com/ma71supraturbo/articles.html i like this article too http://www.geocities.com/ma71supratu...93cdsupra.html |
#9 |
oh, i didn't see all your other links.... we posted like the same thing
#10 | |
![]() Quote:
As like what supragirrl said, the differences are the turbochargers(ct12s), the injectors(440vs550cc), ecu, and the egr system. Japan rated that car at the time as 280ps because of a "gentlemens agreement" to not start horsepower wars. In actuality, both u.s. and jdm supra tt dyno (dyno dynamics) around 270-280rwhp when in good condition in factory form. So basically in stock form they are slightly "identical". When modifying past 400rwhp on the jdm version, they usually swap in the stock export 550cc injectors and ecu. To be a little more specific, the jdm ct12b's are a .42 a/r turbo housing. The major and minor of the ceramic turbine blades are 60mm and 48mm and the compressor side is 62mm and 39mm. For the U.S. ct12b's they use a .53 a/r turbine housing. The major and minor are 52mm and 44mm for the steel turbine blades and 58mm and 39mm for the compressor side. The U.S. spec supra tt is only capable of around 540rwhp on the factory 550cc injectors, and thats at 80+% duty cycle(pretty much maxxed out). The factory U.S. spec turbochargers are only capable of around 490rwhp(give or take a few) as the turbos are out of its efficiency range past that. (there are no known compressor maps for the ct12b's released. But there are similar sized turbos out there (all old style, very similar)with compressor maps that can be used as a rough guide) The sweet spot(and daily driver reliability) for the tt's imho are around 18-20psi(Ive seen 25psi, but it had cams,nitrous and head work made like 500+rwhp), anymore is just heated charge air(got dyno graphs and air temps at diff. psi levels). I have pictures (couple different cases)of overboosted U.S. ct12b's that came apart due to insanely high shaft speeds that it wasnt meant to reach.(20+psi=max boost). Just my fifty cents. |
Thread Tools | |
Display Modes | |
new toyota supra 2007 | admin | The Future of the Toyota Supra | 216 | 12-28-2011 10:22 AM |
1983 supra engine question | 101jinx101 | MKII Supra | 0 | 12-06-2007 10:47 AM |
