Old 01-03-2006, 11:04 PM   #21
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by SKILMATIC
Awwe now thats awesome. You see helping people is much more satisfying. Thanks for doing this.
I'm glad to hear that you agree. There really is no substitute for posting helpful & useful information, either publically, or via PM...
Life begins at 30psi.
Old 01-04-2006, 02:57 AM   #22
suprafann
suprafann is on a distinguished road
i would PM or email but lets keep it here since the topic has been started, i would love it if you would reply here, that way if anyoen else runs into this problem they can use search and etc...
Ne wayz soembody told me it looks like a high mileage engine that didnt use synthetic oil.
Hopefully that wou;ldnt effect teh engine too much
suprafann is offline   Reply With Quote
Old 01-04-2006, 03:45 AM   #23
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by suprafann
...Ne wayz soembody told me it looks like a high mileage engine that didnt use synthetic oil. Hopefully that wou;ldnt effect teh engine too muchHopefully that wou;ldnt effect teh engine too much
Honestly it's hard to say...it might have already affected the engine and/or the turbocharger(s), but the first priority is the compression test. If it passes the compression test (along with a driving test to ensure it still boosts well) and you end up purchasing it, then let us know ... I'll post some steps you can take to flush the old oil out.
Old 01-04-2006, 07:41 AM   #24
SKILMATIC
SKILMATIC is on a distinguished road
Like pwpanas said its hard to say. We dont exactly know how long it has been running on what types of oil. We dont know how often the oil changes were done. The most wear an tear would occur on your bearings from improper oil use.
SKILMATIC is offline   Reply With Quote
Old 01-04-2006, 09:12 AM   #25
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
there's no real way to see what condition the bearing side of your motor is in... realistically you can only tear it down then find out...
do you currently own the car or are you "going" to own the car?
without tearing it down i think its just pretty much gonna be drive it till something happens
just make sure it's currently not knocking in the bottom end, always make sure it's topped up with oil and make sure you oil pressure readings are good
Pics of my build.
Do a diagnostic first!
Old 01-04-2006, 12:46 PM   #26
pwpanas
Supra Owner
pwpanas's Avatar
...The most wear an tear would occur on your bearings from improper oil use.
The most wear and tear would have occurred on the engine bearings of the Mkiv Supra you're planning to buy if it was ever run with an extremely low oil level, and/or if a very large shot of NO2 was installed and regularly used on the car. Suprafann, in addition to checking for other signs of poor maintenance, also be sure to check carefully for signs of NO2 installation (eg. a hole drilled, tapped & then plugged in the throttle body), as well as 'standard' bpu modifications, before you make your final offer to the seller.
Old 01-07-2006, 08:07 AM   #27
suprafann
well illl be picking it up on wednesdy if it checks out
wat im going to do is have the seller do a compression test at his shop.than go to toyota to have them check the undercarriage and body......as i wanna make sure the frame is straight
when i test drive it, what should i look/listen for....say i full throttle it, and than what should i look/listen for at normal driving
Old 01-07-2006, 10:19 AM   #28
lethalwithasupra
lethalwithasupra is on a distinguished road
when you got that pic of the oil cap were you able to drive it then or hear it running ? does it actually do anything strange ?
compression test is prolly a good idea. could you take it to a check place and have them to a Vehicle Information Report type of thing ? they'll do a better check and i'd say they'll be cheaper than toyota.
is " the seller " a car yard or what ? don't let a second hand car yard to a compression test on a supra. please. i work up the road from one. just don't.
... and it'll be the guy with the sign who does the job.
So I bought this old Honda bike, an NSR250. Bit of a street racer, I guess. I'm told they're fast.
Delivering it home with a friend driving the Supra for the first time. I drop gears and make a scream from the twin pipes flowing down this pony's flanks and it takes off like it's tail's on fire.
I look back when the Honda gets to its tap-out and the Supra's only two lengths behind. No one I've let ride my bike has told me its slow, they've all loved the thing. That car is a good thing indeed.
lethalwithasupra is offline   Reply With Quote
Old 01-07-2006, 03:09 PM   #29
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by lethalwithasupra
...don't let a second hand car yard to a compression test on a supra. please. i work up the road from one. just don't.
I agree 100%, and I'll take this advice one step further. Since most courts regard any used car transaction as "as - is ... buyer beware", YOU are responsible for the accuracy of the compression test figures. In other words, there may be no recourse if you purchase the car and find it needs a new/rebuilt engine a few weeks later. I'm sorry to say that I've heard back from some buyers about compression tests done by sellers and I hear things like "160s across the board". I hope it's not news to anyone that, even if that information is near-accurate, that statement alone is insufficiently detailed to give you a good indication of the health of the engine.
Imho, either you need to do the compression test yourself, or you need to pay an independent mechanic to do it (preferrably one experienced with the Mkiv Supra turbo). If you can't find anyone nearby, post here and I'll find you a Supra owner in the area who can direct you to an objective, skilled resource that can do the compression test.
Lastly, if the engine has many thousands of miles on it since the last sparkplug change, the PCV hoses get so rock hard they may have to be cut off, and the plastic coilpack connectors may crack they're removed. Either you, or the person/shop performing the compression test, should have some spare PCV hoses and coilpack connectors available just in case. Fwiw, I'd suggest you agree with the seller ahead of time that if it fails the compression test, he compensates you for the cost of any hoses or connectors that need to be replaced.
Old 01-08-2006, 01:48 AM   #30
suprafann
well the seller said if i find a problem with it he will pay for my tickets back lol
Ne way i was thinking about taking it to TOYOTA for a compression test, and have them check the body
they said it would be 89 bucks for compression (not sure if thats most cars or excluding supras etc)
they want 189 to check hoses/belts...not sure if ill pay that much for that job
and i have to call again tos ee how much they charge for a frame check
what you gusy think, IS Toyota reliable?
PANAS...the car is located in texas...
wise opinions please cyanide-is-a-way-out MKIII Supra 6 01-05-2008 10:39 PM
Money to spend...upgrade path opinions. Put in your .02 cents! godgaveussid MKIII Supra 10 11-25-2007 01:39 AM
Pull-a-part opinions needed finaltable MKIII Supra 3 08-15-2007 02:19 AM
Opinions Needed!!!!!!!!!!!111 justin1642 MKIII Supra 0 02-07-2007 06:29 PM
