Old 02-03-2006, 08:21 PM   #1
Hennessey
Hennessey is on a distinguished road
Default Non turbo Kit, quick question
I was looking at this kit
http://www.suprastore.com/bolost2notot.html
1. Do i have to buy stage 1 first?
2. it says it has everything you need to turbo a stock mkiv, but is that true?
as in can i just bolt it on and thats it? (i would have the work professionally done)
thanks
Hennessey is offline   Reply With Quote
Old 02-04-2006, 04:47 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
as in can i just bolt it on and thats it? (i would have the work professionally done)...
Although I've never worked with that kit specifically, it does apear to be complete.
No you don't have to buy stage 1 first. "Stage 2" just refers to the horsepower level (i.e. turbocharger size and overall injector capability).
I'd suggest you call Suprastore and ask them about it, just to confirm. If you decide to purchase, when it arrives lay out the kit and be sure you understand how everything works and hooks together. If you take this step, you (or you and your installer) should be able to identify any missing parts.
Lastly note that kit specifies ""approximately"" 525hp, which is "approximately" 445rwhp through a 5spd, and "approximately" 395rwhp through an auto. This kit does not suggest it would be possible to push even one more horsepower than that at even at max boost (even if you change the turbo someday). If you wish to change to a bigger turbo someday, it may require other supporting modifications including a thicker headgasket and different injectors...and that's only if the other turbo you want to use fits at all. Also note you may need to run race fuel to support even those numbers.
Life begins at 30psi.
quick question about turbo red_armie_soviet MKIII Supra 4 10-04-2007 03:39 AM
Turbo lag question. rnoswal MKIII Supra 6 02-12-2006 05:42 AM
quick question re: turbo inlet born2drv MKIII Supra 2 01-11-2006 05:02 PM
