#2 |
7M POWAH! ;)
well really compression = pistons as there is some of the compression difference... also the head gasket is a different thickness
the crank and rods i believe are identical.. where it differs is in the pistons... also it's missing the oil squirters that the turbo block has and the sump is designed different for the oil return for the turbos and the non turbo block doesn't have the feeds for the turbo's that's about all i can think of off the top of my head... also the head's i would assume are different... but i am in no way a mk4 expert so do a bit of research ![]() good luck
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
JDM 6MGE engines avilable | Supra Goddess | MKII Supra | 12 | 03-27-2015 12:32 AM |
mk3 supra body differences | suprra_girl | MKIII FAQ | 37 | 07-17-2009 02:36 AM |
7mgte-1jz-mk engines | supraquest | Non-Generation Specific Questions | 2 | 01-07-2009 07:46 PM |
Why are JDM engines available at all? | finaltable | Non-Generation Specific Questions | 3 | 06-09-2007 12:51 AM |
