Old 08-18-2015, 09:06 AM   #11
Jackal101
Jackal101 is on a distinguished road
Originally Posted by sethrupenthal View Post
Yes, I read the clutch is rated plenty high but I have a nasty habit of installing clutches that are stronger than the assembly and snapping bell housing bolts and/or cv shaft bolts. (Just had to replace stock bolts on a4 fwd 1.8t 5sp running 25psi). From what I've read, the general consensus is that the 01e can take a 1000+hp beating and just as much torque. I was curious about the adapter itself...presumably it would have to be pretty thick to handle that much power and that assumes the load of a small car. My application is a heavy full size pickup. Many CNC/engineering companies here stateside shy away from this type of custom work citing "liability concerns".
Do you have a build thread started for this? I'd love to see it as it progresses.
Hi mate,
I have threads on www.gt40s.com under Wings, wheels and keels if I remeber correctly. Search for "Vigilante" I also have a thread on www.supraforums.com under builds and projects.
The adaptor plate is 25mm thick if I remember correctly. New Engineering does various engine and gearbox combinations. The owner drives a 1jz landrover and he is busy with another for his wife with a 2jz. So he knows his story.
He is alo going to make my side shafts which he gives a life time guarrantee on. If I break one he replaces it.
BTW, he does all the side shafts for the racing guys at Killarney race track in Cape Town. He hinself races there too.
Jackal101 is offline   Reply With Quote
Old 08-18-2015, 02:47 PM   #12
sethrupenthal
sethrupenthal is on a distinguished road
Originally Posted by Jackal101 View Post
Hi mate,
Was unable to find New Engineering (found "New Way" which seems to be a generator co). PM me with their contact info, please.
I found your GT40 build thread. VERY nice. Kudos to you, my friend. I enjoyed seeing the changes in direction as the build progressed. BTW the MB 6.0 V12 would have been awesome, but I reckon your 2jz choice is the best. I had a similar idea, then opted for the simplicity of japanese design over the complexity of German engineering. Posting link for anyone else who might be interested.
http://www.gt40s.com/forum/wings-whe...e-project.html
sethrupenthal is offline   Reply With Quote
Old 08-18-2015, 03:09 PM   #13
Jackal101
Thanks buddy,
I will post their particulars here.
Cheers
Jackal
Old 08-18-2015, 03:13 PM   #14
Jackal101
Thanks buddy,
Cheers
Jackal
Guys name is Michael Le Seur
Address and number (South Africa so have to add +27)
http://www.netpages.co.za/Brackenfel...ng-262168.html
I will find out what there email is in the morning
cheers
Jackal
Old 08-19-2015, 02:39 PM   #15
sethrupenthal
cheers
Jackal
Thank you, sir.
Old 08-20-2015, 09:53 AM   #16
Jackal101
Thank you, sir.
Hi bro.
Spoke to Michael. He says no problem. You can email him at Michael@newengineering.co.za
Cheers
Jackal
Old 08-21-2015, 03:39 AM   #17
sethrupenthal
Hi bro.
Cheers
Jackal
Thanks, mate!
Engine Project nelly26 MKIII Supra 0 10-26-2006 11:25 AM
