Old 03-01-2006, 08:42 PM   #1
kenshi1023
kenshi1023 is on a distinguished road
Default Mid Engine 1jz/2jz project
I did some searches before posting, couldn't find anything on converting a 1jz or 2jz to a mid engine layout.
my question is can a 5sp solara tranny be mate with a 1jz or 2jz motor, so that it can be put into a mid engine design layout. are there other trannies that can be use for this purpose. thanks
kenshi1023 is offline   Reply With Quote
Old 05-17-2015, 07:50 AM   #2
Jackal101
Jackal101 is on a distinguished road
Default Mid engine 2 jz
I used an Audi 01e six speed box mated to a 2jz-gte. Costs ran +/- $1500 to mate the two. That included custom flywheel, custom adapter plate, custom clutch (3 pack), custom release bearing housing. I will be picking it up on Monday from the Engineering shop.
Car is based on Lambo Murcie but with my own tweaks. Side intakes added Celica headlights, Still have to pull the mold for the body and then do the body.
Jackal101 is offline   Reply With Quote
Old 06-05-2015, 06:59 AM   #3
Jackal101
Here is my 2jz-gte mated to an Audi 01e 6 speed transmission.
Old 06-27-2015, 03:54 PM   #4
Nice! Did you make that custom adapter plate yourself? If so, can you tell us anything about how you did it?
Old 06-29-2015, 06:30 AM   #5
Jackal101
Hi. No I did not. I had it made at an Engineering shop close by. New Engineering. They also made a custom flywheel and custom 2 pack clutch. (3 pack wouldn't fit and I did not want them to cut on the box itself. 2 pack is good for 1000bhp though)
My friend is doing my chassis here is a pic or two.
Cheers
Name:	Chassis - Vigi.jpg
ID:	4947   Click image for larger version
Name:	Chassis - Vigi3.jpg
ID:	4948   Click image for larger version
ID:	4949   Click image for larger version
Old 06-29-2015, 06:37 AM   #6
Jackal101
Here is a better pic of the adaptor plate and flywheel and also a pic of my body I am doing
Name:	Vigi flywheel.jpg
Old 06-29-2015, 06:43 AM   #7
Jackal101
I will have to post pics of the body later. First have to reduce the photos in size. They won't upload here.
Old 08-17-2015, 03:13 AM   #8
sethrupenthal
sethrupenthal is on a distinguished road
Default Nice Set-up
Very nice power train. I actually found this by googling "2jz to 01e adapter". I was thinking about outsourcing this to BNC, but might just use your local engineering co. Did they indicate a rated capacity for torque, power, weight, etc.?
Is motor stock or built? Trans?
I'm in design mode right now, and both components seem to be just about bullet proof with the right mods.
sethrupenthal is offline   Reply With Quote
Old 08-17-2015, 09:00 AM   #9
Jackal101
Hi mate,
Motor is standard. I have already bought a Garret GTX35R turbo and will be using a local ecu (Dictator) to try and get to 800 BHP. Already bought a 100mm throttle body etc. Also LS1 coils.
Remember I am located in South Africa. New Engineering reckons the custom 2 pack clutch is good for 1000BHP. Not sure how the 01e would stand up to that though. What I have heard at the local race track is that I should not have any problems.
Cheers.
Jackal
Old 08-17-2015, 01:39 PM   #10
sethrupenthal
Hi mate,
Cheers.
Jackal
Yes, I read the clutch is rated plenty high but I have a nasty habit of installing clutches that are stronger than the assembly and snapping bell housing bolts and/or cv shaft bolts. (Just had to replace stock bolts on a4 fwd 1.8t 5sp running 25psi). From what I've read, the general consensus is that the 01e can take a 1000+hp beating and just as much torque. I was curious about the adapter itself...presumably it would have to be pretty thick to handle that much power and that assumes the load of a small car. My application is a heavy full size pickup. Many CNC/engineering companies here stateside shy away from this type of custom work citing "liability concerns".
Do you have a build thread started for this? I'd love to see it as it progresses.
Engine Project nelly26 MKIII Supra 0 10-26-2006 11:25 AM
