Old 03-21-2006, 07:03 PM   #1
jim83
jim83 is on a distinguished road
Question a little info ????
hey guys im brand new on here , im looking to buy a supra twin-turbo manual but can someone explain what the differnce is between the variations also the difference between uk spec and j-spec cars because i might be looking to import one , also how easy are the to mod i got a 300zx tt at the moment , i wanted to mod it up to 500bhp but i was looking at ten grand to do !!!! if i want to get this kind of power out of a supra what mods would be needed ???? will i have change the internals ????
jim83 is offline   Reply With Quote
Old 03-22-2006, 02:17 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by jim83
...can someone explain what the differnce is between the variations...
The US-spec model has larger injectors, a longer-duration intake cam, and larger turbos.
...how easy are the to mod...
Very:
http://www.mkiv.com/techarticles/index.html
...i wanted to mod it up to 500bhp but i was looking at ten grand to do !!!! if i want to get this kind of power out of a supra what mods would be needed ???? will i have change the internals ????
No, you will not have to change the internals. Do you mean 500hp at the crank or at the wheels (I've seen conflicting definitions online for "bhp"...and according to SAE, "bhp" is an obsolete term). For 500 at the crank, all you'll need is 'bpu++++' modifications. For 500 at the wheels, you'll need a small single turbo. You'll also need to run some race fuel or water/meth injection.
Life begins at 30psi.
Tranny ? Need Info! SilverBullet05 Non-Generation Specific Questions 0 07-07-2008 09:45 PM
info on 1984 supra 84cuddy MKII Supra 1 11-22-2007 11:00 AM
Info on MkIII Supra Nic MKIII Supra 2 03-15-2007 11:27 PM
Emissions Test Info in "Your" Area/State mrnickleye Off Topic Forum 9 05-01-2006 01:11 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
