Old 03-28-2006, 10:40 PM   #1
NeoFuture
NeoFuture is on a distinguished road
Default Hey
ive bought a non turbo automagic 1994 at last
whats the most effecient stuff to do to it to start with for more perfomance on a tight budget
NeoFuture is offline   Reply With Quote
Old 03-31-2006, 10:50 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
hey
welcome to the forum and i'm sure our mk4 man will soon reply
Pics of my build.
Do a diagnostic first!
Old 04-02-2006, 02:16 AM   #3
pwpanas
Supra Owner
pwpanas's Avatar
The most efficient stuff to do with it is to get a GReddy BCC ($100, to prevent fuel cut), put on a downpipe ($300, to eliminate excess back pressure from the turbochargers), and then raise the boost. You can raise the boost with something as simple as partially clamping the correct hose in the engine bay (i.e. you don't need an expensive boost controller, only a ten cent clamp). Last but not least, you should install a boost gauge ($50+) to ensure you don't boost over 16psi on 93 octane pump gas (to keep your engine healthy over the long term).
Life begins at 30psi.
